Question about Mad Dog Multimedia Dominator (MD-12XDVDRW-SE) (MD12XDVDRWSE) DVD±RW Burner
Mad Dog Hard Drive - Immediate Help
My Mad Dog external hard drive seems to be making noises(like it's receiving a fax, chirping), and does not read on desktop as E Drive....may have been bumped, thanks greatly for any immediate help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
The grand majority of these external hard drives can't withstand being dropped from 3 inches, and some can't be dropped 1/2 inch. In other words, to retrieve your data, you will have to send it to a specialist, who will charge you between $300 to $1500 to get the data, with no guarantees. What a deal. I had a Fantom 120 gb, my dog knocked it over, and by by data. The fact that it is making noises means it has been knocked out of kilter. Try calling them with your warranty, but I bet it won't cover it. The whole industry is a big ripoff, as they do not warn you that you can lose everything at the drop of a hat (as it were). Only one company guarantees a drop of 7 feet that I know of. Better off to back up your data using an online secure system. Some cost only $4.95/month. Sorry.
Posted on Mar 24, 2008
SOURCE:
Chirping cricket sound
oopppsss.. time for replacement
Jun 19, 2017 | Western Digital 500GB My Passport...
Need manual for mad dog multimedia external wiring harnness
Unfortunately, Mad Dog Multimedia went out of business years ago, and no longer provide support services or documentation for any of their products.
Unless you can find another one of these external drive cases on a sale rack somewhere, or being sold used by an individual, your chances of finding the original manual are extremely slim.
May 03, 2011 | Mad Dog Multimedia USB 2.0 External Drive...
My computer does not read the device
Make sure you're using two cables, one for data and one for power. That means you need two USB ports to run this device (or one USB port and one 5 VDC power supply with suitable plug).
Mar 13, 2011 | Mad Dog Multimedia USB 2.0 External Drive...
I have a Mad Dog Mulltimedia external usb floppy dsrive. It does not work on my windows 7 computer. Can you help me find a driver or whatever I need? Virginia Wilbur
Mad Dog is, unfortunately, out of business by all indications and there is no support available from them. I suspect that Windows 7 will not have a driver that is compatible with the enclosure's interface. Depending upon what brand/model of actual hard drive is inside the enclosure (Western Digital, Seagate, whatever) you may be able to dismantle the enclosure, remove the actual disk drive, and use it in another enclosure with an up-to-date interface. That is only a suggestion...it would require a certain amount of mechanical expertise and a good phillips screwdriver ;-)
Dec 29, 2010 | Mad Dog Multimedia USB 2.0 External Drive...
My Mad Dog external hard drive does not show up as a drive. How do I get this to show so I can access my information.
Connect it to a different computer, to see if the device is working at all.
If not, and if the Mad Dog is still under warranty, then exercise the warranty to get it repaired/replaced.
Otherwise, disassemble the casing, remove the disk-drive,
and connect the disk-drive as a "slave" disk-drive in a desktop computer, to see if the disk-drive is OK. This would imply that the USB-to-disk-drive interface inside the casing is the problem.
Aug 18, 2010 | Mad Dog Multimedia MegaVault USB 2.0...
I have a mad dog external hard drive with data on it; now my computer is saying that the drive is unreadable and corrupted. I can't open it to scan the disc for errors or viruses. What can I do to...
Is this a hard drive or an optical drive? The model under which it is listed implies that it is a internal DVD drive.
If, in fact, it is a hard drive (fixed platter(s)), you might consider buying SpinRite from Gibson Research. I have recovered data from many drives over the years with it that were considered 'dead.'
SpinRite
May 22, 2010 | Mad Dog Multimedia MD20XSTFI Internal DVD...
I just changed the HD in case and the computer cant find it
follow these steps: plug in the hard drive go to start-my computer-device manager -usb -action(Scan for hardware changes) if is not recognized this way then go to this site and download the program is free http://www.radarsync.com/.
Dec 10, 2009 | Mad Dog Multimedia USB 2.0 External Drive...
I have a Mad Dog hard drive enclosure that I did have a Western Digital WD400 hard drive in. Now I need to recover some data from a Western Digital WD1600. The ribbin that connected to the hard drive is...
It would cost just as much to purchase a "SERILLEL" adapter as it would cost to purchase another "empty" external hard-drive case that has support for the newer-style 'SATA' hard-drive.
If you have a newer desktop-computer, you probably have an unused SATA port on your motherboard, and an unused SATA power-connector. Temporarily connect the SATA drive to your motherboard, and do the recovery.
Oct 26, 2009 | Mad Dog Multimedia Computers & Internet
Installed a 500G hard drive in the 3.5" enclosure. It doesn't recognize it as a hard drive. How do I fix?
Make sure that your HD was installed properly in enclosure. Remove the cable then atached again.
Aug 20, 2009 | Mad Dog Multimedia MegaVault USB 2.0...
External hard drive not appearing on desktop
try start computer into windows now connect drive
now restart coputer leave drive connected when back in windows it should read it
Dec 21, 2008 | Mad Dog Multimedia Dominator (MDED1F)...
Computers & Internet Logo
550 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
