Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a craftsman riding mower that will not start. Model No.917258473 Serial No.062597C003426 It did try to fire over before it did nothing,I have installed a new solenoid & starter and tried to jump start it with my pickup truck for 30 mins. It acts like it not getting any fire to the starter at all. My question is do you have a solution to the problem.
I am not sure about your particular model, but mine has a fuse in the wiring harness. It is a blade type automotive fuse and if it blows, nothing happens when you turn the key. No click, no nothing. You may be able to tell if it is blown by visual inspection. The fusible link is visible thru a small window in the fuse. The best way is to pull it and check for continuity with a multimeter.
Posted on Apr 30, 2010
  • 143 Answers
First I would check the spark plug. Remove the plug and with the high tension lead fitted earth the plug against the engine, turn the engine and see if the plug is sparking. Hold the metal part of the plug and you wont get shocked. If you have a spark then your problem is fuel, you will have check the carb. and filters. If you have no spark , it could be the wires or the high tension coil.
Posted on Apr 26, 2010
Craftsman riding mower what year was it made model#cv14s
First find the Model Number and Serial number. Next go to Craftsman.com follow menu to Manuals. Enter the model and serial numbers. This should bring up the Manual with the manufacturing Date.
Dec 12, 2014 | Craftsman Garden
Engine not starting
It sounds like no electricity is making it to the starter. Several things may be wrong. Check to see if the fuse has blown. It should be behind the dash. Your starter switch may be bad. You can unhook it and use a jump wire from the positive side of the battery to the wire connection on the starter to see if it will turn over. The switch under the seat that detects someones sitting on the mower could be bad. You can unhook it and place a piece of wire in the connections to make a complete circuit then try to start it.
Apr 26, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding mower won't start. It's a Craftsman
Check your seat switch and brake switch for loose wires.Most likely brake switch do to no spark at plugs,see if PTO switch/lever isnt on.
Nov 22, 2009 | Craftsman Garden
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need belt diagram for Craftsman riding mower
Try the link here but use the MODEL number instead.
Hope this helps!
Oct 01, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
257 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
