Question about IBM Lenovo ThinkPad T60p Notebook
Potentially dead IBM Thinkpad screen however need diagnosis help
I have an IBM Thinkpad T60P laptop with the 15" 1600x1200 screen that currently does not display anything on screen.
Connecting the machine to an external monitor works correctly and also the backlight on the monitor comes on (I believe) however no display. I believe it is a faulty panel but before I go spending £££ on a new panel, CCFL, inverter etc I'd like to get your opinion on how to diagnose and locate the exact problem.
Any help would be appreciative...
Many thanks. Dino
  • 243 Answers
SOURCE: T41 IBM thinkpad monitor goes off
Saw exactly the same think on another t41 i was trying to fix. If it was moved at all screen went off.
Turned out it was corrosion on the motherboard that was causing the problem.
Has it been liquid damaged or got damp in the past?
Posted on Jan 07, 2008
  • 230 Answers
SOURCE: double display with my IBM think pad T43
have you tried Function F7/F8 ?
Make sure that your display driver is installed correctly.
I had the same Laptop as you did and was able to have dual monitor.
Also check your Display driver in your control panel and make sure it set to dual monitor.
Posted on May 12, 2008
SOURCE: Thinkpad T23 screen problem
If you take the casing apart on your monitor and pull the chip out gentley, look at the ribbon wire that goes from the monitor to your computer. It may be cracked from opening and closing. That is what was wrong with mine and it sounds like we have the same problem. I had to use another montintor until my tech group could get me a new one. Hope this helps.
Posted on Dec 08, 2008
  • 68 Answers
SOURCE: blank screen and unresponsive hard drive nothing on external monitor either
did u manage to enter your bios?if not, then i suspect your ram has a problem..normally notebooks are equipped with two modem...try to use one of them only....also, try to change the position(means slot A is for RAM A and slot B is for RAM B- try to place RAM A to slot B first n test your notebook)
hope it will help ; )
Posted on May 27, 2009
  • 32281 Answers
SOURCE: ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Posted on Jun 14, 2009
I need a manual for t60p ibm thinkpad
You can download a manual for this model laptop from this WEB site.
Apr 07, 2013 | Computers & Internet
User manual for T60p
You can check the link below:
Nov 09, 2011 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
Laptop ibm t60 screen white, but works fine with external lcd screen connected by VGA cable
Check your laptop's LCD connections. One of the below items may need replacement or you may need to just reinsert them, might be loose.
- LCD cable
- LCD inverter
- LCD itself
NOTE: Most often, the LCD inverter is the culprit.
Hope this helps.
Jun 25, 2011 | IBM 92P6569 DVD/CD-RW for ThinkPad R50,...
Bottom half of laptop screen is colors with white lines vertically. Was able to control by changing position of screen, no lnger able to do that. Thin k Pad Lenovo T60
Try to hook up an external monitor just to check that it is not a problem with the video card of the laptop. Most likely the LCD cable is loose or the LCD inverter needs to be replaced.
Hope this helps.
May 25, 2011 | IBM 92P6569 DVD/CD-RW for ThinkPad R50,...
I just installed 2 gigs of RAM into my Thinkpad T60p and the BIOS does not see it. Yikes! what can be wrong. It seems to be located correctly.
One of the RAM module may be incompatible. Are both RAM modules the same type and make?
Try inserting 1Gb RAM module at a time to see if the BIOS can see the RAM.
Nov 17, 2010 | IBM Lenovo ThinkPad T60p Notebook
Red Green stripes on IBM Thnikpad T60p tft monitor
Those are dead pixels if you want to get rid of them you will probably need to replace the monitor. They will probably charge you an arm and a leg to replace it so you might get a second quote from Computer repair shop.
Jan 31, 2009 | IBM Lenovo ThinkPad T60p Notebook
IBM Lenovo ThinkPad T60p Notebook Logo
164 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
