Question about Canon imageRUNNER 400S Copier
Does the Canon Imagerunner c3100 have a hard drive to store copied images?
  • Canon Expert
  • 287 Answers
Hello kaiserma.Yes the C3100 has a HDD.It is 20G.To locate it, remove the rear cover.In the upper right section you will see a silver aluminum box.The hard drive is located wthin it.I hope this helps. :-)
Posted on May 08, 2010
Testimonial: "Thanks - this was exactly what I needed! Thanks again"
  • MARCEL CORZO Nov 30, 2011
    I get an error code E00602-0202, which is a hard drive problem (from what I have reading in the forum), I want to replace the disk drive myself, but I searched thec canon link and I don't know which software is the one I need to install, and if I can install directly from my PC connecting the new hard drive to it? Any help would be appreciated. Thanks.
Canon Imagerunner C3100 shows error code E00012-0001
Drum motor error
Check the connector and replace the motor
Jan 17, 2013 | Canon imageRunner C3100 Copier
Canon Ir C3100 Error 000070-0002
A E000070-0002 deals with the transfer belt. I believe it deals with the two tension arms, one may be broken...... It is not easy to get the unit out of the copier.... Good Luck
Jun 26, 2011 | Canon imageRunner C3100 Copier
Canon6570 printer Error Code E000012-0001. thanks!
sir i have a canon 6570 image runner
0001 code is coming again & again
plz ask me what i do
Jan 23, 2011 | Canon imageRunner C3100 Copier
I have error code e000020-0081 on a conon c3100 copier
You need to clean the image patch sensor, wich is located above the drum unit in copier.Use a lint free clotch.
OR, how many copies do you have with your drum? If over the 60000 replace the drum unit.
Apr 20, 2010 | Canon imageRunner C3100 Copier
Canon image runner c3100 switched to dynamic ip addressing on new router but now ir c3100 does not work , i gave the printer an ip address and i can ping it from my computer and when i send print packets...
ok... turn dhcp on on the cannon... then turn it off and on... the cannon should pull the right settings... then turn dhcp off... and change the ip to the one you selected... all should be well after that... if it isn't... then you need to find the IP range of your router and get an IP address below it or above it.... say your IP address range is from 192.168.1.100 to 192.168.1.255 then you want an IP address below 192.168.1.100
Dec 16, 2009 | Canon imageRunner C3100 Copier
How to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Aug 22, 2009 | Canon imageRunner C3100 Copier
If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
Mar 29, 2009 | Canon imageRunner C3100 Copier
Streaking on the IR C3100
Dear sir; Streak line, I have two things come out from my mind I need to clear; no. 1 do you make copy through ADF and got streaking line? if your answer is "yes" would you to make another copy direct from glass plateform, if copy coming out same problem that's means you need to replace drum cleaning blade, if copy coming out perfect then you need to clean the glass especial the narrow piece if they have, try it out and let me know, good luck!
HAVE A HAPPY HOLIDAY!!!
Dec 17, 2008 | Canon imageRunner C3100 Copier
Obtaing proir copys from ir 500
In practical terms? No.
a determined and experienced hacker intent on industrial espionage could remove the hard drive and rebuild the image from the deleted data but I dont think that is what you are asking. Just something to keep in mind when you scrap or sell the machine. The hard drive should be removed and destroyed.
Jul 25, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 400S Copier Logo
407 people viewed this question
old marine
old marine
