Question about Craftsman 2500 PSI Briggs Stratton Powered Pressure Washer
Craftsman power washer 580.768332- Unloader problem; does the seat of the piston need to be removed to do an overhaul with the kit on the unloader?
5 Suggested Answers
redbeard00
  • 957 Answers
SOURCE: How do you clean the unloader valve on a power washer pump?
The unloader valve usually is replaced. I dont know if you can get o-rings for it. But if you want to take it apart, there will be a crown or cap style nut just below the spring. Unscrew it completely and you will be able to remove the spool. There is just a series of o-rings on it.
Posted on May 12, 2009
  • 174 Answers
SOURCE: clean and unloader valve on Karcher hd3500
Hi:
Cleaning it is not enough. You need to make sure the o-rings are in good shape and grease it with a very very good waterproof grease. Here is a schematic of the pump. The unloader is parts 7 to 13 on D-2
Posted on Sep 10, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
mrhappyface
  • 205 Answers
SOURCE: I have a Craftsman compressor
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Posted on Jun 15, 2011
HOW TO CLEAN UNLOADER VALVE
Good luck. It is best to get the repair kit for your unloader. Many unloaders are not marked very well and it is difficult to find the kit needed. They have all of the parts that need replacing. ( usually a new ball or two, seats, o-rings and seals) The kits usually have a diagram of what goes where. You might want to make your own drawing and match each part you take out with the part in the kit and where it goes. It is amazing how they all look the same when they are out of the unloader. Did this go here or there????
Sep 23, 2014 | Karcher Garden
Do the spring end caps inside the 315747GS unloader valve face the spring or the ends of the valve
This parts diagram for the pump should answer your question http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/580751651.html?p=22
Jun 08, 2014 | Craftsman 2500 PSI Briggs & Stratton...
Craftsman Pressure Washer stalls out when trigger is released
Pressure unloader is stuck in closed position. Have to know what type of unloader it has to see how to get to the "ball" check. Probably rusted to the seat. Might have to replace the seat, orings and ball.
Apr 12, 2014 | Garden
Power washer not spraying hard
Hi Mike
You could have one are two problems with the pressure washer.
1...pump for pressure washer worn and needs washer/seal replacement.
2...Need to adjust the pressure discharge relief valve to the needed pressure.
Please take time to rate me
Bud
Mar 28, 2013 | FAIP Powerwasher Universal Pressure Washer...
How to replace unloader valve
almost all pressure washers have the "unloader valve very accesable on the side of the unit. look for a brass valve body that appears to have at least 2 barrels. disconect water lines and remove the attaching fasten.ers. install is reverse of removal.
Jun 30, 2012 | Craftsman 2700 PSI Briggs Stratton...
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Not sprayer engine stop
This is an indication that the unloader not working properly. When you release the trigger the unloader senses the increase in pressure and bypasses the water into the water inlet. When the unloader is not working and you release the trigger, the water pressure builds quickly and overcomes the power of the engine shutting it down. Here is the manual for your machine, http://www.pressurewashersdirect.com/manuals/Simpson_WaterBlaster%20manual_2.pdf
and some information about troubleshooting from the manual.
"Not Unloading. Leak in Gunvalve or Hose. Repair gun leak . Replace leaking or broken hoses. Debris or wear in Check Valve. Remove Check Valve parts and clean. Check O-Ring. Reface with emery cloth, or replace checkvalve. Damaged Piston U-Cup. Rebuild Unloader Valve (Service Center)."
Usually when the unloader fails the pressure regulator will most likely need to be replaced as the unloader is usually incorporated within. For now try lowering the pressure some and just tie the trigger open untill you can service. Good luck.
Jul 14, 2010 | Simpson WS4050V Water Shotgun 4000 Psi...
I have a pressure washer with a faip 3 piston pump. the other day i was using it and it stopped unloading. i cleaned the unloader and it didn't help. I bought a new one and it still won't work. I e-mailed...
I think your main problem is that the unloader valve needs to be lubricated. Use the very best water resistant bearing grease you can find. If you can e-mail me a pic of your unloader assembly I can try to explain how to set it up. firehead@roges.com
Sep 14, 2009 | Honda Garden
Where is the unloader valve on my pressure washer
is not necessarily a cap, but could be a screw in plug, that should be close to the hose hook-up on the pump Inside there there should be a round ball and a spring that you can tighten or loosen to adjust the unloader and if it has been used ALOT, where the ball seats there could be grooves cut in there and you might need to get a valve kit to fix it
Sep 05, 2009 | Karcher 2500 PSI Pressure Washer
Craftsman 2500 PSI Briggs  Stratton Powered Pressure Washer Logo
542 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
