Question about Dometic Rooftop RV Air Conditioner
I have a question on Coleman AC
I got an Coleman mach air conditioner on my pop-up. Everything worked when I bought it. I brought it home the next day popped it up and plugged it in with an extension cord to a GFI outlet and the GFI blew. Then I plugged into another outlet and then the AC could not turn on. I reset the breaker switch and checked and I had power to my switch on the AC. The switches would work because I could test them with my tester. So it is in between the switches and the motor, any ideas?
Well the repair came by and he put freon in the unit but it still blows the same the problem is my a/c is not blowing the air out hard enough u can feel the cold air when you are by the vents but its not blowing out hard
Posted on Jul 22, 2011
  • Dometic Master
  • 6,674 Answers
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Posted on Apr 26, 2010
Coleman mach ac blower stopped
bad motor windings.replace the motor
May 07, 2012 | Coleman Mach III Air Conditioner
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
No cold air
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the GreenCOLEMAN R.V. PRODUCTS
Bar.
You can get Service Support or Email address and Phone numbers.
May 30, 2010 | Coleman Mach III Air Conditioner
Coleman Mach 3 ac unit tries to start compressor & kicks off
50 foot extention cord not a problem IF it is at least 10 gauge and plugged in to a 20 amp circuit
Your compressor is shutting down for a lack of AC voltage would be my best guess
Jul 27, 2009 | Coleman Mach III Air Conditioner
Coleman mach wire schematics?
GO TO
www.rvcomfort.com
then click on contact us on the Green Bar.
Aug 04, 2008 | Coleman Mach 15 Air Conditioner
Need to find schematic on coleman 7333c886 ac
http://www.rvcomfort.com/rvp/tech_info/manuals.php
This is the web site for Coleman AC's from RVP. Go under the service manual for the 6700, 7000, 8000 and 9000 series air conditioners and they should have everything that you need.
Hope this helps,
Jeff
Jul 15, 2008 | Coleman Mach 15 Air Conditioner
Coleman TSR RV air conditioner
There should be a solar panel on top of your roof top air conditoner. There is a quick disonnect for the solar panel. If the monitor light illuminates the solar panel is working.
May 21, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
182 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
