Question about Coleman Powermate Proforce 2500 Generator
The generator will not start. When I spray Gumout into the carborator, the engine runs for about 2 to 3 seconds then shuts off no matter what position the choke is in. Please advise.
  • 251 Answers
Hi, carefully remove the bowl from the carb and clean out any water/rust/dirt etc allow fuel to pass through the carb till it drips out , reattach bowl and leave it for 10 mins then try starting it .
hope this helps
Posted on Apr 29, 2010
My Ryobi 3500 generator starts but will not run
I've found this vid helpful:
https://www.youtube.com/watch?v=5AKKuuXUM6I
* check and clean out air filter.
* drain out old fuel from lines around on/off fuel valve.
* You may need to drain and force flush out fuel filter (I used the carborator cleaner to force out water in filter.)
* re-assemble fuel lines and clamp.
* pull out choke lever to full choke.
* Pull start cord (or start switch) several times to prime fuel line.
* Turn on switches to ready generator for start up.
* Try several times to start.
* If it won't start then spray in carborator cleaner or Generator start spay into the air intake (with air filter sponge removed. Just a short burst is needed.
* Try starting again.
* Pull at least 3 times before spraying any additional cleaner to prevent flooding.
* If generator does not even turn over then there is a spark or ignition problem. Pull the spark plug to clean and check gap. (see your specs for recommended gap.)
* try spray starting method again.
* if your still having problems (with not turning over at all) then you will have to take it to a small engine shop or contact the vendor for service. Check your warranty.
* Once the generator has started. Keep it running till smooth operation. Adjusting the choke to normal open position may take a few minutes till the engine has time to warm up. Install air filter and close up all covers. Allow for a 5 min run and check by connecting a load to the electrical out put. (plug in a saw or other heavy duty power tool) The generator should adjust to the additional load.
Aloha, ukeboy57
May 09, 2018 | Electrical Supplies
My Yokohma generator/welder will start, but will not stay running Why
It is most likely needing a deep cleaning of the carburetor. With the fuels we are now having to use the carburetor passages tends to clogged more easily when they sit unused.
Nov 12, 2014 | Electrical Supplies
Why my 1998 ford e250 idle for a few second when sprayed gumout in the idle body
if it will not keep running then you most likely not getting gas to the engine. might be time for a new fuel pump
Jun 03, 2014 | Denso 1998 Ford E250 Econoline 5.4L...
Engine Turns Over But Will Not Start
1. check the oil
2. Spray starting fluid in card 1 second
3. try to start
if no
pull spark plug and with leather gloves hold 1/8 from cooling fins
if spark = YES spray starting fluid in to hole where spark plug goes. repeat step 3. If spark = NO remove flywheel and check points clean contacts and recheck for spark.
if runs for short while after apray of starting fluid - clean carborator ( see youtube)
replace spark
Nov 10, 2013 | Cub Cadet Garden
Yamaha ef1000 will start then push choke in and generator stops
clean tank fuel lines air filter and completely clean all carb parts and jets just did mine runs mint now did the same thing i also put in a new spark plug changed the oil a good once over goes a long way just take your time use a good carb cleaner like crc or gumout and check the jets they have small holes on the sides that can clog up hope this helps
May 07, 2012 | Yamaha 1,000 Watt Portable Generator...
GENERATOR WON'T START. IT HAS NOT BEEN STARTED IN ABOUT THREE YEARS.IT DID START AFTER I REPLACED SPARK PLUG,BUT ONLY FOR ABOUT 30 SECONDS..ALSO SPRAYED STARTING FUID IN CARBERATOR. NO GO.
FIND THE FUEL SHUT OFF VALVE.IF IT WAS CLOSED WHEN YOU HAD IT RUNNING,THE FIX IS AS SIMPLE AS DRAIN OLD FUEL,REPLACE WITH FRESH GASOLINE,OPEN THE VALVE TRY TO CRANK IT AGAIN.
IF IT WAS OPEN WHEN IT WAS RUNNING,SOUR GASOLINE AND VARNISH HAS LIKLEY GOT TO THE CARBORATOR.
REMOVE THE AIR FILTER,LOCATE THE BOLT IN THE CENTER,ON THE BOTTOM OF THE CARBORATOR BOWL AND REMOVE IT. CAREFULLY EASE THE BOWL STRAIT DOWN,AS NOT TO BEND THE TAB THAT CONTROLS THE FLOAT LEVEL,OR LOSE THE FUEL INLET JET. EXAMIN THE BOWL FOR CORROSION OR GUNK.
THIS IS AN INDICATION THE CARBORATOR MAY BE PLUGED WITH GUNK,WHICH COMES FROM GASOLINE SOURING AND TURNING TO VARNISH AS IT EVAPORATES OVER TIME.
ON THE CARBORATOR,WHERE THE BOWL WAS TAKEN OFF,IN THE CENTER ON THE BOTTOM NOTICE THE FUEL PICK UP TUBE,TAKE A PIPE CLEANER AND CLEAN IT BY PUSHING STRAIT UP AND DOWN A FEW TIMES,THEN FLUSH IT WITH CARB CLEANER.
REPEAT THIS UNTIL IT IS CLEAR.
LOOK CLOSELY AT THE SIDE OF THE PICK UP TUBE FOR A VERY SMALL HOLE,WITH A SMALL WIRE,CLEAR THE HOLE AND FLUSH WITH CARB CLEANER.
CAREFULLY REPLACE THE BOWL AS NOT TO BEND THE TAB ON THE FLOAT,MAKE SURE THE NEEDLE JET IS IN THE NEEDLE SEAT AS YOU PUSH THE BOWL INTO PLACE.
PUT THE BOWL BOLT BACK IN,CAREFUL NOT TO OVER TIGHTEN IT.
WITH FRESH GASOLINE IN THE TANK,AND THE FUEL VALVE OPEN,YOU ARE READY TO TRY CRANKING IT.
IT MAY TAKE A FEW TRYS.
IF YOU FEEL CLEANING THE FUEL SYSTEM IS TOO MUCH FOR YOU,PLEASE DO NOT ATTEMPT THIS.TAKE THE MACHINE TO A SMALL ENGINE MECHANIC.
YOU MAY CAUSE COSTLY DAMAGE TO DELICATE PARTS OR UNINTENTIONALLY CHANGE THE FLOAT LEVEL CAUSING FLOODING OR STARVING OF FUEL TO THE ENGINE.
BEST OF LUCK...
Nov 05, 2010 | Coleman Powermate Proforce 2500 Generator
Colman Powermate Generator will not stay running
This overflow can be caused by:
1. The float sticking
2. Gas inside of the float air chambers
3. The needle and seat have debris in them or a r damaged.
It is not a difficult fix but it does mandate removal of the carburetor float bowl.
You could probably do this yourself. It is much easier if you place the generator on a high work area so you can see the float and needle once you have the float bowl removed. Just make sure you do not drop the float assy so far that the needle comes out of the seat unless you have to remove the hinge pin SCREW for the float to clear the debris near the needles' pointed rubber head.
Thanks for using FixYa
Kelly
Mar 22, 2010 | Coleman 1850 Watts Generator Each...
Sometimes car won't start after driving. Can start it by spraying carborator cleaner in where air cleaner is. Replaced fuel regulator, didn't help. Doesn't do it all of the time, but want it fixed. If it...
Try cleaning the IAC valve locate near the air cleaner intake hole . Remove the aircleaner duct work. And when the car does start. Run engine at 1200 rpms or so. Spray carb cleaner inside the hole to the sides of the walls. you can see 2 small holes to the side of the walls. That is the IAC. Turn engine off ,let the cleaner soak in. Then restart the engine and spray some more. when I say spray , I mean a good 10 seconds of spraying right at the little holes . See if your car starts running better. if this does not work, replace the IAC it is on the outside of the fuel intake . You can also try the MAF sensor. Mass Airflow Sensor located on the big pipe on the air cleaning system.
Jan 06, 2010 | Mercedes-Benz 560-Series Cars & Trucks
Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Apr 11, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
My Ariens snowblower (model #924048) won't start
Dissamble carburator. Spray Carburator cleaner  through passages, and wash out bowl. Dump gasoilne if old.  Reassemble Carburator. PS count the turns on the two Jet (mixing) screws and place back into the same position after cleaning passages.
Dec 27, 2008 | Ariens Garden
Coleman Powermate Proforce 2500 Generator Logo
312 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
