Question about Dell 924 All-in-One InkJet Printer
Don't know basic install
I have new color and black and white cartidges and I don't know how to get the shuttle to come to the center so I can install them.
  • 407 Answers
Hi sir
if you not setup your new cartidges you see you old cartidges how to setup then see and properly open you printer jack. then see you a jack when jack open cartidges open ...then replace old cartidges.
Posted on Mar 24, 2008
    Genius:
  • 1,142 Answers
I am trying to fix a dryer wall outlet but the colors are black white and naked copper I don't know which is neutral and ground. White can u please help
I don't know where you live (what Country) But usually the the bare copper is ground in the USA. or if there is a green it is a ground. The black and whites are where you get your power. I can not nor will I tell you with out being there and having a meter. You should call a local electrician and ask him if white is hot or black is hot. Thats all I can say. I dont want to tell you wrong if someone wired it backwards. Call a qualified electrician. You don't want to mess with electricity if you do not know what you are doing. CALL AN ELECTRICIAN AND ASK
Apr 10, 2012 | Dryers
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
I have a malibu ML 88T low voltage transformer. It was working fine and I saw the manual on/off and turned it, (i should have left it alone). The lights did not come on, so I turned the manual on/off...
You can do it yourself.
Anybody that knows 'hardwired' and observed timer is making humming sound can wire up a timer.
If M88T timer dial is not rotating, but power pack is making humming sound, then that says timer is receiving power but clock motor has gone bad.
There are no replacement clock motors for power packs.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
To wire a new timer:
Click circuit breakers until the humming sound turns off.
Turn breaker back on to confirm that humming sound is associated with that breaker.
Buy a tester at local hardware and ask them how to use it.
Tester will give you assurance that power is off when connecting new timer.
Outdoors: put down dry boards to stand on, never stand on bare soil or wet/damp surface, don't touch anything metal and don't hold metal screwdriver in mouth while working on electric circuit. Wear gloves if you want. And don't sweat.
With 120volt circuit, as long as you are not grounded, which means that you are not touching soil, or anything that grounds back to soil, then you will not get electrocuted. You can get shocked only if power is still turned on at circuit breaker, and it will be surprising, but it won't kill you as long as you're not grounded. All electricity goes back into the earth to complete circuit.
Open the box where timer is hardwired.
Use tester on black wire. To confirm power is off.
Typical 120volt circuit: Black wire is Hot and carries voltage. White wire is neutral and completes the circuit back to ground. Bare copper wire is ground and serves as redundant safety.
Old 88T timer will be wired black-to-black, white-to-white, and green-to-bare copper.
Take photo of wiring to avoid confusion. Post photo on flickr and add a comment with link to photo for another pair of eyes on situation.
Cut off end of new timer wire, strip insulation with knife and attach wires same way previous timer was connected.
http://waterheatertimer.org/How-to-twist-electric-wire.html
To install ordinary 120Volt outlet so timer can plug in: Buy outlet from hardware: Black hot wire connects to brass-colored screw, white neutral wire connects to silver-colored screw, bare ground wire connects to green-colored screw.
Open following link to see basic circuits:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Aug 08, 2011 | Intermatic 24hr Outdoor Timer
My video cassette recorder will only record in black and white now.
If the electronics haven't crapped out, it's likely dirty. It takes considerably more signal to have color than B&W. Cleaning the heads should help. If you don't know how, let me know and I'll walk you through it.
Alternately, a few of the VHS and 8mm units had a black and white mode setting in the menus. Recording B&W movies in color mode caused some oddball effects, from time to time, so they offered a B&W mode. It was a short lived option because people didn't want to bother with it, and it occasionally got enabled accidentally, leading to complaints and visits to service centers.
Jul 04, 2011 | Sony Televison & Video
I need to print a lot of only black and white documents, I have full cartridges of black ink but the color is empty. For some reason it keeps printing the black off the color cartridge. I need to find out...
Since I don't know what operating system you have on your computer, here are the steps for all Windows operating system from Canon for your printer. If these don't work, let me know but usually once you change the settings for black and white only, it works fine.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#ServiceAndSupport
Apr 16, 2011 | Canon PIXMA MX310 All-In-One Printer
2007 TOYOTA SOLARA DASH LIGHTS SHUT OFF WHEN CAR IS IN DRIVE .
Don,t know why this problem happens....but to get the dash working again remove the dash cluster. There are two white plugs in back of the cluster. In the larger of the two which is dead center on top of the cluster, cut the wire which is in pin #2. It will either be a black/white for the convertibles or a black for all others. It will be next to a white/red wire. Just tape off each end then tape up the harness. No connections are made. Don' t know why this works but it does. Problem seems to happen when remote starts are installed.
Jun 29, 2010 | 2007 Toyota Solara
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Installed black print cartridge will not print now?
nope, there should be no tape on the cartridge. This is preventing the ink from coming out.
Jul 30, 2008 | Lexmark X6170 All-In-One InkJet Printer
C4180 Professional Photo Pack
Yes, plastic cartidge holder is provided to you to store HP 337 (black inkjet print cartridge) as you remove it to install a new HP 338 ( Photo Cartidge).
Remember, below combination of Cartidges for used for specific purposes:
Black and color cartidge  for general Printing of Documents.
Black, Color, Photo Cartidge to Print Photos.
Color cartidge , photo Cartidge and gray cartidge is specially used when you to print copies of photos  with great quality.
I hope that this should resolve the issue for you.
You can mail me at thumuvikram@rediffmail.com for further assistance, I'll be glad to help you.
Bye
Oct 16, 2007 | HP PhotoSmart C4180 All-in-One Color...
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
