Question about Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
What size belt does a eureka whirlwind take - Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
  • 438 Answers
Your Eureka Whirlwind 4388 takes Eureka Style "U" Belts, Part number 54312.
Here's a direct link back to that belt on our website if you need to purchase one:
http://www.govacuum.com/1541.html
Feel free to ask further questions by using the comment field on the repair page.
Thanks,
Chris J.
GoVacuum.com
Posted on Apr 27, 2010
reddevil6
  • 1673 Answers
SOURCE: How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
Posted on Jan 29, 2008
reddevil6
  • 1673 Answers
SOURCE: eureka whirlwind light speed
Wish you had given your model number, but most of these, there are 2 screws on the top cover, near the front, remove those and the top comes off, the belt and brush roll are exposed.
Posted on Feb 05, 2008
SOURCE: eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Posted on Jul 24, 2008
  • 10865 Answers
SOURCE: Need user/owners manual for Eureka Whirlwind Big Cup model 4686
hello chris. here is the link to use to get your downloadable manual
http://www.eureka.com/owners_guide.jsp
Posted on Jun 19, 2009
  • 50 Answers
SOURCE: how to change belt on eureka whirlwind
You will first need to remove the hood to gain access to the belt and brush roller. Turn the machine upside down, place the handle on the floor and the base on a counter. You will find several screws that hold on the hood, remove them. Turn the machine back to the upright position and remove the hood. On the right hand side,if your looking the front you will find where the belt goes. At the back you will find a silver shaft sticking out, put the new belt on there first. Then put the brush roller through the belt so it is in the carved out section of the brush roller. Then grab the brush roller by each end and stretch the belt till the brush roller fits back into the base. Turn the brush roller 3 compleat turns backwards and 3 forward to seat the belt in the proper position.
Then put back on the hood.
Posted on May 08, 2010
What size belt??
The Eureka Whirlwind 4489 uses style U belts, and you can find the Belt Package Assembly- Style U 2pk at the following link:
http://www.vacpartswarehouse.com/Eureka-Electrolux-Sanitaire-Belt-U-Style-2-pack-p/61120.htm
The broken belt usually stays trapped within the housing, so when you remove the necessary pieces in order to access the beater bar, you should find the remnants of the original belt, which you could also use to determine the size you need for a new belt. You might even get lucky and find that the belt itself is ok, but had gotten derailed somehow! Also good to remember is that there is often a second belt sealed within the packaging and instruction manual, so you may already have a spare belt on hand if you stashed the owner's manual somewhere.
Hope that helps! Please rate as helpful if so :) Thanks!
Jul 01, 2014 | Eureka Whirlwind 4489 Upright Vacuum
I live at zip code 24060 and I need a new belt for my Eureka Whirlwind. Where can buy this?
You can get them at Walmart.
Look on the nameplate and it will tell you which belt too buy
(Probably a "U" belt)
Sep 09, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
How do I replace the belt on my mom's Eureka Whirlwind litespeed 12 amp 15" ?
take the cover off from the bottom there should be clips or screws on the bottom.and work the old belt off and new one on
Aug 12, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Type of belt for it?
Your Eureka Whirlwind model 4489 uses the Eureka Style U belt. There are several different U belts that Eureka makes, including a generic one that's made by Eureka under the Smart Choice name. Eureka also makes a Eureka Style U belt Extended Life, apparently increase the life of your Belt.
Here are links to all of the Eureka U belts that will fit your model:
Generic Eureka U Belt made by Eureka for Smart Choice Brand
Standard Eureka U Belt Part 54312
Extended Life Eureka U Belt Part 61120
If you have any questions, or need help installing this belt, please just reply using the comment section on the repair page here on Fixya, and I'll be more then happy to answer any follow up questions that you may have.
If you found this helpful, please be so kind and rate the repair, or leave feedback for me, this is greatly appreciated by the Fixya community.
Thanks,
Chris Jones
GoVacuum.com
May 17, 2010 | Eureka Whirlwind 4489 Upright Vacuum
The vacuum roller won't turn but the belt is fine Eureka Whirlwind Litespeed
The belt may look fine but it's probably stretched out. Rubber belts are usually good for about 1 year. The tension of the belt is what allows it to turn under the strain of the carpet. Make sure the brushroll spins freely when held out of the machine. Eureka brushrolls are prone to melt down on the end caps. If that has happened you will need a new one.
May 01, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
How do I change belt for Eureka Whirlwind Lite "Boss" model 450 A
Remove the 4 screws on the yellow top of the vacuum. The yellow plate will pop up exposing the belt and roller.
Jan 20, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
Dec 27, 2007 | Eureka WhirlWind 4381 Upright Vacuum
Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum Logo
395 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
