Question about Health & Beauty
5768BL Biggest Loser Body Fat scale need manual
  • 2712 Answers
SOURCE: body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: digital scale question
Digital scales purport to measure your body fat through a process called BIA, or bioelectrical impedance analysis. Essentially, it clocks the speed that electricity travels through you. The scale runs a low-level electric current through your body, using your feet as positive and negative electrodes. The current encounters different levels of impedance, or resistance, from fat versus muscle. The scale measures this impedance, and throws it together with other factors (age, sex, height) to come up with your BMI, or body mass index.
SOURCE: Watchers WW-87 Body Fat Glass Scale
Hi
At this web site bottom left hand corner there is an instruction manual
http://www.conair.com/weight-watchers-glass-digital-scale-p-667-2_60_38.html
Posted on Dec 16, 2008
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
  • 39 Answers
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Posted on Jan 21, 2010
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
How come my scale will shut off on it own and not display my weight
depends it may have a power save feature, this will shut of the scale after a set amount of seconds. or it may be faulty. check the user guide to see if it is power save.
Aug 29, 2014 | Taylor Biggest Loser 7206 Electronic Cal...
I have a taylor food scale model:3865BL and need a manual for it
I have Taylor the Biggest loser model 3865 BL and I need the Manual.
Apr 01, 2014 | Taylor Health & Beauty
Shows 0.0lb no weight
Well I figured it out, just in case anyone comes across this. Turn it over, push the button on the top middle of the scale, hold, turn back over, wait until "C" appears on the screen, stand on scale, now it works. :)
Jan 10, 2012 | Taylor Biggest Loser 7206 Electronic Cal...
I keep getting err 1 message on the screen
Take it to your nearest service centre. it could be the PCB which is giving problem
Jul 04, 2011 | Taylor Biggest Loser 7206 Electronic Cal...
I just need to get a copy of the instructions for the 5758BL Biggest Loser Scales.
Taylor has a number of scales available in The Biggest Loser series for which they make available a link to the Instruction Manuals. See here:
http://www.taylorusa.com/catalogsearch/result/?q=biggest+loser&x=0&y=0
Here are two examples:
The Biggest Loser 7334 Weight Management Electronic Scale with Goal Tracking
http://www.taylorusa.com/media/IBs/7334_ib.pdf
Taylor The Biggest Loser 73343 Lithium Electronic Scale
http://www.taylorusa.com/the-biggest-loser-lithium-electronic-scale.html
Unfortunately after browsing their site I found nothing close to the model number you provided. If you see a model that is similar in looks and features suggest you see if the instructions for that model are of use to you. You may also find there FAQs to be of assistance:
Alernatively send an inquiry direct to Taylor Precision Products:
http://www.taylorusa.com/taylor-support
Apr 23, 2011 | Vacuums
Taylor 5568 scale will not display lbs - just kgs when I tap and step on it. It's the Biggest Loser body comp model. It was working fine,displaying lbs, then one morning it ws just kgs and I can't get it...
Don't know if this will help, but here is the manual.....see my photobucket link:
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Jan 10, 2011 | Taylor 55684102 BODY FAT BODY WATER...
THE SCALE WE HAVE IS A "TAYLOR CAL MAX BIGGEST LOSER SCALE" AND IT ALWAYS SHOWS "ERR1" WHEN YOU STEO ON IT.
When you step on it and get the err1 message step off wait a few seconds and step back on, remember that while the scale is processing your weight you MUST remain STILL.
good luck
Aug 12, 2010 | Taylor Biggest Loser 7206 Electronic Cal...
What does Err mean?
I am very well under the maximum weight and I keep getting the Err message. Just not a quality sale.
Apr 16, 2010 | Taylor Biggest Loser 7303 Electronic Scale...
Health & Beauty Logo
229 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
