Question about Q2 Designs Intel Celeron 410 Notebook
Charger where can i get the charger to this laptop??
    Novelist:
  • 128 Answers
Best buy sells a pretty good selections of replacement power supplies for laptops.
Expect to spend from $60-$100.
Good luck,
James.
Please vote 4 thumbs for me!!!
Posted on Apr 26, 2010
Blinking laptop charger
Your laptop charger may be dying, do not use this kind of laptop anymore until you test your laptop using a good working laptop charger. If you don't have it, then you can buy it online (eBay.com is a good source), or you can go to local computer store to buy a good quality laptop charger.
Mar 06, 2014 | Samsung Computers & Internet
Tip
How to troubleshoot a laptop charger.
  • Step 1 Wrap your charger's exposed wiring with electrical tape before proceeding. This will help to prevent any kind of electrical hazard or further damage.
  • Step 2 Push the wire next to the charger base (the connecting tip near the laptop end) side to side to see if you can get a current to connect. This is a temporary solution, but it can help you salvage your files so that you can work with them on a different computer.
  • Step 3 Make sure that it isn't a battery problem. Many laptop owners believe their charger is the problem when their battery is charging. Laptop batteries generally begin to lose the ability to hold a charge after two to three years of heavy usage. Try removing your laptop battery. If the computer still runs, the charger is not the problem.
  • Step 4 Check to see if the issue lies in your computer. You can do this by testing out an alternate charger on the laptop--if the charger still does not work, it's an internal laptop issue. For this kind of power system problem, you will probably have to send your computer to its manufacturer rather than a local repair shop.
  • Step 5 Replace your charger. A replacement charger is usually easy to find and quite affordable. Instead of going to a local electronics retailer where universal chargers can cost $100 or more, look online for your specific model's charger. Some chargers can be purchased for as little as $5
  • on Jul 21, 2010 | Computers & Internet
    Using a Dell Inspiron no apparent power to laptop with our without a adapter. New universal laptop charger...still light on charger goes off as soon as connected into laptop power port.
    hi
    sounds like the laptop has a motherboard fault, dell laptops need to be run from dell chargers only and at correct voltage and correct amps output. the information is normally provided on lable on the base of the laptop, universal chargers do not normally work on dell laptops, would suggest you try and use original dell charger .
    Aug 07, 2013 | Computers & Internet
    My computer shuts down when i plug in the charger
    Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
    Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
    My computer says plugged in, not charging
    Dead battery. Test battery, try another cord/charger to verify.
    Dec 01, 2012 | Toshiba Satellite A135-S4527 Notebook
    Toshiba satellite won't turn on
    Before you make a decision about the next step, maybe you would like to know why the laptop charger is not working. Here are some commonly found reasons for this problem.
    You have been using the wrong laptop charger for your machine, or someone else has been using your laptop charger for another machine. This may seem like a harmless act, but it affects the battery on your laptop, and charger you are using as well.
    Your laptop battery has become weak and worn out from excessive use. Due to this the battery is not charging at all (or charging very slowly) when you plug in the charger. In this case there is absolutely nothing wrong with the charger itself.
    The wire of the laptop charger has got a distinct curve at one point, and this is restricting it from transmitting power. You need to look out for such bends in the wire, as this will ruin the efficiency of the charger in no time.
    This may sound elemental and stupid to some, but it does happen to many people. Maybe you are simply using the wrong laptop charger by mistake, or maybe you have failed to switch on the power switch. Check both these things to be sure.
    Any of these potential causes could be the reason behind your laptop charger not working. As a result of these, either the mains power lead of your charger may be damaged, or the power supply unit may be damaged, or maybe the lead itself is damaged or broken somewhere, or some circuitry inside the laptop is damaged, and not responding to the charger. It's hard to accurately tell which of these problems could be the real cause of your laptop battery not charging, without physically examining the machine.
    Solutions and Answers
    Now if you are well versed in computer hardware you can attempt to fix this yourself. Most people cannot do this, and it is advisable for them to visit a computer repair shop instead. They will examine the laptop charger not working problem, and suggest some suitable remedies for it. Depending on your budget, you can choose an option that suits you and simultaneously solves your problem. Here are some recommended solutions.
    Buy a brand new charger which will definitely solve your problem of charging the laptop for a long time.
    Replacement Toshiba Satellite M305 AC Adapter 75Watt 19V 3.95A
    If you're hesitant to pay that amount, you can try and purchase a second hand laptop charger from eBay.
    Get your's repaired and pay the repair shop the fees that they charge.
    If your warranty is still valid, you can simply get the laptop charger replaced.
    Reference: http://www.buzzle.com/articles/laptop-charger-not-working.html
    Oct 27, 2012 | Toshiba Satellite M305D Notebook
    My compaq cq40 laptop charger is not working
    • You have been using the wrong laptop charger for your machine, or someone else has been using your laptop charger for another machine. This may seem like a harmless act, but it affects the battery on your laptop, and charger you are using as well.
    • Your laptop battery has become weak and worn out from excessive use. Due to this the battery is not charging at all (or charging very slowly) when you plug in the charger. In this case there is absolutely nothing wrong with the charger itself.
    • The wire of the laptop charger has got a distinct curve at one point, and this is restricting it from transmitting power. You need to look out for such bends in the wire, as this will ruin the efficiency of the charger in no time.
    • This may sound elemental and stupid to some, but it does happen to many people. Maybe you are simply using the wrong laptop charger by mistake, or maybe you have failed to switch on the power switch. Check both these things to be sure.
    • Buy a brand new charger which will definitely solve your problem of charging the laptop for a long time.
    Compaq Presario CQ40 Laptop Charger
    • If you're hesitant to pay that amount, you can try and purchase a second hand laptop charger from eBay.
    • Get your's repaired and pay the repair shop the fees that they charge.
    • If your warranty is still valid, you can simply get the laptop charger replaced.
    Apr 25, 2011 | Compaq Presario CQ40 Series Laptop Charger...
    Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
    It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
    Oct 31, 2010 | HP Compaq nx5000 Notebook
    Laptop charger melting
    The cause was high resistance in the charger, probably from a poor solder joint. It is likely your laptop was not damaged. You can use another charger.
    Mar 01, 2009 | Computers & Internet
    Open Questions:
    Save Your Important Data Getting Lost With Cloud Backup Solution of Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
    May 26, 2018 | Individual Computers & Internet
    See all Q2 Designs Intel Celeron 410 Notebook Questions
    Q2 Designs Intel Celeron 410 Notebook  Logo
    Top Q2 Designs Computers & Internet Experts
    David Payne
    David Payne
    Are you a Q2 Designs Computer and Internet Expert? Answer questions, earn points and help others
