Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
Weed eater will not run in high speed but will idle
  • 54 Answers
Lack of fuel is my first thought. Check to be sure the trigger control is working at the carb. From there I would suspect plugged fuel line or plugged carb, (most likely contaminated fuel) either way I would suggest someone that knows about these. Hope this helps
Posted on Apr 26, 2010
What my carburetor screws are supposed to be set at on weed eater model gti15
One is the low speed or idle adjustment the other is the high speed. The settings are based on how the engine runs. There really isn't a way to say it should be set here or here....it depends on how well it runs.
Oct 15, 2016 | Garden
What would be wrong with my trimmer if it idles good but wants to die when i try to accelerate
It either needs the L mixture screw adjusted (counterclockwise 1/8 to 1/4 of a turn) or the metering diaphragm inside the carb has become brittle and is not opening the needle valve to allow enough gas to flow into the H (High speed ) fuel circuit to allow it to run. Don't confuse the L mixture screw with the Idle speed screw. The idle speed screw has a Philips head and the L speed mixture screw has a small unconventional head that a normal screwdriver does NOT fit.
Aug 06, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Need carbureator jet settings for snapper SKU 952711718 weed eater motor
screw all the way in and back out 3/4 of a turn. Then adjust the bottom screw out 1/4 turn at a time till it cranks and continue adjusting till it idles good.
Then adjust the top screw till it stays running when going to high speed abruptly.
Jul 22, 2011 | Garden
What are the carb screw adjustments for a weed eater xt 85t trimmer set at
The two screws are marked 'H' and 'L' for high speed and idle/low speed running. You could start with the screws turned out about 1 1/2 turns each and then have to slowly adjust the 'L' screw to obtain aht ebest idling speed with the wngine warm. When you have the engine idling satisfactorily, open the throttle and adjust the 'H' screw to obtain the best high running condition. The settings will vary slightly from engine to engine depending on the engine condition, so it is basically a trial and error set up.
Jul 11, 2011 | Garden
My Ryobi cs30 weed eater tends to shut off after I release the throttle.
Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
Sep 06, 2010 | Ryobi Garden
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan Pro weed eater won't accelerate.
check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed eater GTI 17 won't run on high speed
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
May 19, 2009 | Poulan Genuine Weedeater Part # 36006-128
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
838 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
