Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Rubber antenna has become old and cracked and fell off almost both of my 250's exposing the coil wire antenna underneath. How to repair or buy another?
    President:
  • 2,761 Answers
Many operators just wrap the coil with electrical tape. The antennas are considered to be non-replaceable, so they are not offered as repair parts. And if they were offered, they would probably cost more than new radios would.
Bill B
Posted on Apr 27, 2010
  • Ed Williams
    Ed Williams Dec 17, 2012
    Poor support on Motorola's part. Could not possibly cost more than a new radio unless Motorola was purposely trying to gank the consumer.
Can rubber antenna encasement be repaired or replaced on Garmin rino 530? Scratched screen window , too?
If the wire is intact sure just apply some lquid rubber flex seal or sillicone to the cracks. If that dont work call garmon or search ebay, if you cant find just the atenna you my find a broken one. The window repair was pretty expensive but that was a few years ago.
Nov 05, 2016 | Garmin GPS
Can the antenna on a T5820 be replaced?
A replacement antenna is not available from Motorola. You can re-coiling the wire and placing something over it to simulate the original antenna, or wrap it in electrical tape. Exposed the coil will oxidize and the antenna will begin to fail and have shortened range.
The other option is to get another of the same model from ebay and use it for a replacement or parts for your existing unit.
Best regards.
Jan 31, 2013 | Motorola Walkie Talkies 2-Way Radio
What if your walkie talkie antena is chewed on and makes a buzzing sound
If the antenna is exposed that radio will get inductance, normally most walkie talkie antennas are
composed of a coil of bare wire, a shield around the wire to keep out inductance or noise, and
the outer layer to keep it together and protected. if the metal is exposed you can cover the area
with a piece of aluminum foil and wrap it with black tape or electrical rubber tape sold at most
hardware stores or an electrical supplier. or you can go and by another antenna. good luck!
Feb 23, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
N12 Bostitch comp nailer, need a few inner parts. Where can they be located? An inside rubber piece fell apart.
I have seen these parts available on ebay. They are using parts from old Unicatch roofing nailer and Max cn55 coil nailer. I have an old craftsman lathe and cut parts from other nailers to fit. This is hit and miss and does not work as well as max parts. You can be creative or just buy parts from ebay. Good luck
Jan 12, 2011 | Stanley Bostitch N12 Coil Nailer...
My 2004 Audi A4 radio antenna is damaged or
You can fix it yourself. The stealership wants 1500 for diagnostics and replacement. The harness is about $200 at VW. The cabs have a design defect that Audi will not acknowledge nor repair. Here is how you fix it yourself. You need to open the trunk and look at the rubber wire protector on the left side between the trunk and the lid. See picture posted. You don't have to remove any liners. Pull the rubber out of the top and very gently pull it down as far as you can exposing the antenna wires. Remove the black soft wrap
Jul 10, 2010 | 2003 Audi A4 Cabriolet
2008 IS250 can not start engine after driving in a raining day
With engine not running or ignition on, check beginning and end of all wires from battery, via coil to end at spark plugs on engine. Check all are firmly attached ie not loose. Buy a water repellent spray suitable for car engine use ig STP spray or WD40 type and apply reasonably to the wiring that you have checked is OK. Mostly around end connections.
This should seal any cracked rubber seals or small openings that allow water/rain in. Works for me!
Regards
Steve
Oct 21, 2009 | 2006 Lexus Is 250
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
AM/FM stereo receiver often fully "drops" the reception of listened to radio station(s), or reception will often decrease in volume. Repositioning of the receiver's connected antenna wire often has no...
Possible solution. I have fixed two with this problem. When the radio drops to a hard surface, the ferrite coil antenna is the heaviest component on circuit board. Look for cracks in solder or broken wires where attachments to circuit board occurs for this component. Use a fine point soldering iron with low heat.
Oct 12, 2008 | Audio Players & Recorders
2004 Toyota Camry
The solution is for a 4 cylinder
Find the camshaft cover, located at the top of the engine.
There yfind 4 square rubber objects with wires connected to the coils, pull them up, inside the exposed tubes you find the spark plugs.
You will need a 5/8 spark plug socket on an 8" extension with a ratchet to remove the spark plugs.
If you still get troubles, buy the repair manual here
Toyota Car Repair Manuals: Chilton & Haynes
There you can find detailed instrucions with pictures.
Sep 18, 2008 | 2004 Toyota Camry
Garmin c330 cracked screen
You can buy a new C330 now for $125 - $175. It would probably cost that much to repair the old one, I would replace it.
Jul 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
1,072 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
