Question about Yamaha Emx88s Powered PA Mixer System
Emx88s powered mixer
It seemes to work but as soon as sound goes in the limiter swich shuts it of and i can figure out why.is there a way to disconect it?
  • ddtrocks Jun 05, 2008
    I got the same problem....cuts out........comes back on for 2 seconds,then cuts back off....I think it's the limiter switch..can it be disconnected?...you basicaly can't use the P.A. if it constantly cuts out...any solutions?
    Problem Solver:
  • 6 Answers
There is no limit switch. Maybe you are trying to drive too low an impedance load [eg, too many speakers at once]
Posted on Sep 26, 2008
Try shutting the limiter switch off
Posted on Mar 31, 2008
My limiter is always on, no sound
Hi, i would like to know what you have running into the input side of the mixer and also what you have running on the output side. I am unclear, does it make any sound at all? Is your mute button pressed?
Dec 20, 2013 | Kustom KPM 8420 400 Watt Powered Mixer
Where to plug in powered speaker (subwoofer) on yamaha emx88s mixer? I tried monitor but it doesnt work.
To connect powered speakers and/or subwoofers follow the instructions on page 19. Connect the powered speakers from the Main L and Main R.outputs
"MAIN (STEREO) jack: The stereo (MAIN L,R) bus signal which has passed through the MAIN MASTER control and graphic equalizer."
for the subwoofers set the YAMAHA SPEAKER PROCESSING switch on/off for best sound as desribed on page 13.
To test this I would play the song Let's Go by Calvin Harris.
for best results use a matched pair of speakers and subwoofers
such as the Electro Voice Live ELX112/ELX115 to the elx118p subwoofer.
Dec 16, 2013 | Audio Players & Recorders
Can i use powerd spekers with yamaha emx 88s
Yes. You can use powered speakers with this board
Feb 11, 2013 | Yamaha Emx88s Powered PA Mixer System
How to listen thru headphones using a yamaha emx 88 mixer
Did sound for a southern gospel group, using a yorkville powered mixer. Not familiar with your mixer, but, on the Yorkville I had an unused 1/4" line level output with the monitor mix on it. I bought a cigar-sized, 3-channel headphone amplifier / splitter from Radio Shack, called a Boosteroo. Has 1/8" stereo plug that I adapted to the mono output, with a 1/8" stereo to 1/4" mono adaptor. It receives the line level (monitor in our case) signal and supports up to qty 3 - 1/8" plug headphones. Battery operated. No volume control, so I added an inline dial (rheostat) volume control cable. Can't pull up on Radio Shack, now, but, found it available, elsewhere, online. Worked great for me!
Good Luck SdDude
Feb 19, 2012 | Yamaha Emx88s Powered PA Mixer System
Can i run my bose speakers from a powered mixer
You have not mentioned which model of Bose. But anyway simple rule of thumb is make sure your amplifier output power does not exceed the speakers rated power. Speaker power rating can be higher than the amplifier . That way you won't damage the speakers.
Just remember you cannot use a domestic speaker system for a commercial purpose because they are not designed to throw sound over a great distance and cannot generate very high sound pressure levels like professional speakers do. You may not achieve any satisfaction and in return may damage the speakers by turning up the volume very high. Its like trying to race with a domestic car in a formula 1 race !!!!!.Its a loosing battle all the way.
Mar 18, 2011 | Yamaha Emx88s Powered PA Mixer System
Can I plug just one subwoofer into my Yamaha EMX88S? What kind of sub do I need to get for it? Do I need to have 2 subs plugged in for it to sound right? Do I daisy chain the subs with the A15 speakers I...
it is not reccomended to daisy chain passive subs with main speakers, because there is no crossover unit involved. you want a sub to have a crossover frequency around 100hz, so that only frequencies lower than this go through the subs, and not in the main speakers.
you could get away with 1 sub plugged into the mono output on the front, subs dont have to be stereo. you would need a self popwered sub, or an additional amplifier+crossover for passive subs. your best bet would to be to get a powered sub and hook it up to the front panel mono out. powered subs usually already have the crossover built--in.
Nov 25, 2010 | Yamaha Emx88s Powered PA Mixer System
Mixer makes crackling noise while still on stand-by also volume increases involuntarily 35%
We here at proline music are Yahama dealers. It sounds like you could have a few different problems. Your head should go in for service. You can call us at 215-736-8055 if you have any more questions
Jan 15, 2010 | Yamaha Emx88s Powered PA Mixer System
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
Yamaha 860 st
this could be the pre amp transistor or the power amp , it will need to be tested and other components tested also to make sure they are not causing the pre amp to fail or the power amp to fail
if its the pre amp it will be cheap , if its the power amp then it won't be cheap , other small components are cheap
electech
Oct 31, 2008 | Yamaha Emx88s Powered PA Mixer System
Speaker connections
Not usually. They are generally parallelled inside. But if it's the jack itself and not the amp channel thats broken, you should be able to use it successfully.
Sep 13, 2007 | Yamaha Emx88s Powered PA Mixer System
Yamaha Emx88s Powered PA Mixer System Logo
210 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
