Question about Acer Aspire One PC Notebook
My acer the only thing i can do is get in biosbesides that it just keeps flashing and beeping once i have no recovery disk
  • 137 Answers
Try removing the battery; wait 2 minutes, and re-install and try it. Also, check your memory to make sure its seated. You might even consider removing the memory, and using a pencil eraser, cleaning the contacts on the chips and re-install....Good Luck
Posted on Apr 26, 2010
How can recover my deleted/flashed bios
Remove the side panel of the computer case, using the screwdriver to unfasten the screws normally located in the back.
Remove the jumper from its normal position on the motherboard and place it in the recovery position.
Usually, the jumper will need to be moved over one space to cover a previously exposed prong.
If the motherboard does not have a jumper, removing the battery for 30 seconds and then replacing it may have the same effect.
Insert the BIOS flash disk and power on the computer.
If you used a flash tool or utility and did not create a BIOS flash disk before flashing the BIOS, then you will need to do so using a functioning computer.
Since there will be no video, listen for the internal PC speaker to beep.
This means it is performing the BIOS upgrade.
Power down the computer once the BIOS upgrade has been completed.
This process may take some time to complete, so be sure to not turn the computer off before the BIOS upgrade is finished.
Without video, the only way to be sure is to listen to the PC speaker.
When the upgrade is done, the PC speaker will beep again, and the floppy disk drive will turn off.
Replace the jumper back in its normal position and put the side panel of the computer back on.
Power the computer on.
If the computer turns on as normal, the recovery was a success.
hope this helps
Sep 25, 2012 | Compaq Presario 700 470024-192 Notebook
How to delete all my files and restore my acer 5336 aspire
Restoring from the Acer Aspire System Recovery partition is easy Most Aspires will have a second partition that can be used to restore if you do not have CD It is recommended that you make those CD when you first buy the laptop If you don t you run the risk of not being able to install Windows again if that second partition fails Restoring From The Acer Aspire System Recovery Partition Keep in mind that running the recovery will restore the computer to the way it was when you first brought it home Anything you added will be lost so make sure you have program disks passwords favorite websites photos, documents and anything else you need backed up before proceeding with the recovery of your Acer Aspire.Hard Disk Recovery should be enabled by default If it is not you may need to go into your system s BIOS by hitting F2 at boot and enable it under the Advanced tab Once Hard Disk Recovery is enabled, restart the system and hit ALT F10 This will begin restoring from the Aspire system recovery partition. You will be prompted to type six zeros as a security step Type 000000 to proceed You will then see a screen to select your Operating System. Do this and hit enter and the recovery process will begin You Cannot Use The Acer Aspire System Recovery Partition The process for restoring from the Acer Aspire System Recovery partition is similar with all major brand names The most important thing to remember is to always have backups of your data and take a few minutes to burn recovery DVDs using Acer s built in utility. Creating these backup DVD is vital If the hard drive fails you will not be able to perform a recovery from the Acer Aspire system recovery partition Create the media and store it in a safe place along with the rest of your software and computer documentation
Nov 04, 2011 | Acer Aspire AS5336-2524 Laptop
How can i reset my sons acer aspire one notebook. He put a password on it and cant remember it so it needs to be reset
When does the netbook prompt for a password? Is it as soon as you switch it on, or just when you get to Windows? Some Acer Aspire Ones glitch and either put a password in on their own, or corrupt any password entered manually. Correcting this problem is quite technical and involves flashing the system firmware, which can be a problem in itself if the system wants a password as soon as you switch it on.
If it is a Windows password, this can sometimes be removed with software, but it would need to be booted from a CD containing that software. You may need to take (or send) the machine to a computer technician.
Jul 26, 2011 | Acer Aspire One PC Notebook
Hello,my brother repormatted my laptop acer aspire 5732z,and also deleted the recovery.how can i take the recover of this model
Once you delete the recovery partition there isn't any way to get it back. Depending on the model they might have sent you a recovery disk - that should reset the system.
Mar 06, 2011 | Acer Computers & Internet
I'm trying to recover from Backup Disks made when i first got the computer, I've inserted Factory Default disks 1 + 2. Now its asking for the next Disk. Question 1: What is the next Disk to insert?...
The recovery disk consist of 2 DVD, the first is the System Disk (this is first disk to insert), once finished loading, it will ask to insert the second CD (Application and Drivers disk), if in case both are not working, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also place order for a set of Recovery disk by calling Acer Technical support at 1 800 816 2237
Thanks and regards,
Jitha
Jan 19, 2011 | Acer Computers & Internet
How can i install my recovery cd on my acer 5315-2492.
Thanks and regards,
Jitha
Dec 17, 2010 | Acer Aspire 5315 Notebook
How do i a recovery on ace x3400 with out disk
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 26, 2010 | Acer Aspire X3400 PC Desktop
When I turn my netbook on it starts but goes straight to black screen and nothing happens, I went to safe mode but whenever I press Entre it reboots and goes to black screen again, I have no cd-rom ... so...
It appears that the computer is infected with virus and may need full system recovery. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
the computer.
Thanks and regards,
Jitha
Nov 25, 2010 | Acer Aspire One PC Notebook
I've been trying to restore my acer aspire one zg5 to its factory setting, but pressing alt+f10 dont work. i also tried the acer recovery icon and it always show that there is a problem with the...
Follow etaf's instructions above, if you cannot enter the Acer recovery utility try this...
Do not press and hold Alt + F10. Do it like this... From the Acer splash screen press and hold the Alt key while constantly pecking the F10 key.
However, you want to save all of your photos, favorites folder, music etc. on an external disk or flash drive before entering the Acer restore utility above. Anything that DID NOT come pre-installed on your netbook will be lost. Once restored, always, always, always back up your system with an external disk or flash drive as you go, meaning that as you add legitimate software and personal files to your PC and your PC works normally, back it up. It's cheap and the next time this happens you can enter plug in your flash or disk run the restore, and have EVERYTHING back including the stuff that did not come on your system when you bought it.
Mar 24, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3500 Lost Recovery Discs
if you are trying to recover your system using the build in partition, the key you will use is F11 at bootup...
as far as the discs, if you've already created a set with your system you can't make another. if this is the case, you can contact acer and order a set for your particular model.
if you haven't, you can make them with a program, (for acer i believe its called recovery manager?). With vista its easy to find, just start typing "recovery" in the start search bar and click on the relevant program. you can then make the discs with a few blank cds/dvds
Jan 15, 2009 | Acer Aspire 3100-1405 Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
