I am housesitting in a place with a Eurolec front loading washing machine. The door won't open after I've completed a wash. I've waited the 3 minutes after the programme but it still won't open. Any ideas? There is no manual around with other fixes. Thanks
    Brigadier General:
  • 3,513 Answers
Is it giving you a SUD error. Normally this happens due to various reasons. I am posting an article which would guide you to understand the reasons and troubleshoot it.
http://www.fixya.com/support/r3608687-sud_error
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Apr 26, 2010
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
After washing machine end cant open front door to remove washed clothes
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
In your case you might have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Apr 14, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Broke handle off of siemens TOP WD1200 champion, the settings are all in chinese and my clothes are locked inside. help?
If you have used force you have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Mar 30, 2013 | Siemens Washing Machines
EUROLEC Model WM002 Washing Machine How do I open the door after it completes a wash?
im hoping you solved the mystery and would be kind enough to tell me ,how the door opens , moved into a new house with that machine insitu, i cannot get the door open have wet washing inside since yesterday, i would appreciate if you would let me know the secret.
Dec 30, 2010 | Washing Machines
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Hi, I'm housesitting for a friend of mine and I can't get their ASKO 5250 series washing machine to unlock to get my clothes out! It's been stuck for 2 days. HELP!
If the door switch is faulty, you can manually open the door.
Get a flat screw driver or butter knife, open the little door on the bottom left of the machine, from right to left.
this is the lid for the water pump filter. You will see a red plastic ring which is normally screwed on to the machine with a philips head screw. Unscrew the ring from its position and pull down until the door pops open.
Good luck.
Ash
Oct 21, 2009 | Asko W6021 Front Load Washer
Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Dec 15, 2008 | Hotpoint Aquarius WD640 Front Load...
AEG lavamat
For user's manual: Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, & your manual is on line. Wait for at least 3 minutes after the wash is complete, to open the door; do not force the door. The door will not open immediately on the wash being completed.
Dec 25, 2007 | AEG Lavamat W1050 Front Load Washer
When the wash cycle is complete, the door doen' open?
the door may be locked electrically, pneumatically or mechanically. if you unplug it and wait 3 mins see if it opens. if not keep unplugged and check the door lock from the inside to see if there is a tube connected to it- if so pull it off. if no go the lock may be jammed.
Jun 07, 2007 | Supra SW5L50D Front Load Washer / Dryer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
