Question about DeLonghi DCM485 Coffee Maker
Display illuminates - but no display of time, etc.
When I plug in the coffee maker, the backlight illuminates, but the display does not come on. I can brew coffee, but I have to unplug the maker. I pressed the on/off button several times, but it will not turn off. I have to unplug the maker. The coffee maker is about two years ole.
  • tmfried Aug 04, 2008
    I am having the same problem. We have had the unit for less than a month. It brews, but is on all the time, requiring unplugging to turn off. Also, the lights do not illuminate any more.
    Any suggestions on how to fix it?
    [email protected]
  • little_jade Nov 17, 2008
    my display stays black blocked. and nothing really happends
My coffee maker is a Signature Classic and when I turn it on the light turns on but nothing happens. The water doesn't steam and the hot plate under my coffee pot doesn't heat up either, what's wrong I need my coffee?
Posted on Apr 19, 2008
SOURCE:
How do I set the time on my delonghi coffee maker?
hi hazel.
this is all i could find.
How to Set Clock on Delonghi coffee maker? Plug the appliance in; when the coffee machine is connected to the outlet for the first time, "AM 0:00" appears on the display. To set the time, press the SET CLOCK button (fig. 1) and keep it pressed until the correct hour is displayed: then release the but- ton. The time can be set at any moment.
important safeguards save these instructions - De'Longhi
www.delonghi.com/Global/InstructionManuals/GB/GB-1321026IDL.pdf Search for: How to Set Clock on Delonghi coffee maker?.
How do set the time on my delonghi coffee maker Google Search
Nov 01, 2017 | DeLonghi Coffee Makers & Espresso Machines
Unit works fine but LCD display does not illuminate. Can be seen in a low ligfht room but it does not light up like it did for years. Do these LCD displays just die???
The older LCD's have backlights hidden behind the display that burn out over a period of time, this is a tricky repair because the unit needs to be stripped down and the covering removed. Soldering skills for most jobs will be required.
Jun 09, 2012 | Teac CD-X8 CD Shelf System
Display only stays visible at lowest illumination
Sounds like your display's backlight is dying. Your scfreen is in need of replacement. The higher ther brightness setting the faster it quits working.
Sep 25, 2009 | Dell Inspiron 1100 Notebook
How do I set the time on cuisinart coffee maker model cbc-00? Regular time 12 hour intervals Thank You
Set the function knob to CLOCK
Press and hold the HR button for a few seconds if the clock display time is not flashing
Once display time is flashing:
Press and release the HR button a few times for it to advance - it will say "PM" on the display if it is set for PM
Press and release the MIN button to set the mins
Sep 12, 2009 | Cuisinart DCC-1200 Coffee Maker
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Capresso s8 weak coffee
You should probably run a cleaning cycle with a cleaning tablet (the one you drop into the ground coffee shoot, not a decalcifying tab).
This will clean out all the insides where coffee particles and oil can accumulate.
The machine will ask you to run a cleaning cycle after a certain number of cups brewed. But you can also manually start it.
(this is copied from the manual)
You can run a tablet cleaning cycle at anytime even if
the machine does not prompt you,
• READY. Push and hold the Rinse button until display shows
RINSE. The Dial illuminates.
• Turn the Dial until display shows CLEANING. Push the Dial.
Display shows EMPTY DRAWER.
(Follow the rest of instructions for regular cleaning cycle)
Jan 16, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Err4
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Their toll-free telephone number is 1-800-541-6390.
Dec 31, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
DeLonghi DCM485 Coffee Maker Logo
372 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
