Question about Kenmore 80809 Microwave Oven
Control panel will not display anything
The control panel will not display anything, Can I gfix it myself?
  • Kenmore Master
  • 9,098 Answers
We would need the model number to help you.
Since FixYa is not notifying us Experts when folks follow up to posts, you'll have to post a new help request.
Posted on Apr 28, 2010
I can see the fuse , how do I get the front panel off my microwave.
Since you have the top grill off you are almost there. Make sure the plug is out or breaker off. There should be 1 screw at the top center of the control panel. Remove screw and lift up on the control panel. It should lift and then tilt towards you so you can access the fuse.
Mar 01, 2015 | Frigidaire PLMV169DC Microwave Oven
No lights on control panel, but works fine.
there two power supply one for the Magnetron and other low voltage for display drivers and relay.
also it will have 2 fuses one of 10 Amps other for some 500MA replace the second one .
Mar 25, 2014 | Whirlpool RMC275PD Microwave Oven
I have a R-310F microwave and the display no longer give me anything except two lines. The machine works fine but no display or control indications.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 15, 2010 | Sharp Microwave Ovens
No display on LCD panel on my whirlpool microwave
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Feb 11, 2009 | Westinghouse Microwave Ovens
GE Spacemaker microwave, runs only 2 seconds, then stops
The problem you describe on your JVM1650SH02 is a failing "noisy" magnetron which is emitting electrical interference that disrupts your microprocessor.
At my Web site, I have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
You will find a technical sheet hidden behind the grille or behind the controls. It's handy for locating parts and troubleshooting.
You can find an exploded view and parts list by entering your full model number from the tag here, and you can also order parts there.
On your model, you may need to remove the oven from the wall. The installation instructions here will be helpful.
Pro tip: In many GE models, dropping the floor plate that holds the high voltage transformer is necessary to get the magnetron in and out.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Display window doesn't show anything
The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
The repair service saves you a lot over the cost of a new control unit and comes with a full year's guarantee.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 08, 2008 | Sharp R-1510 Microwave Oven
Can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Nov 07, 2006 | GE Advantium 120 Convection/Microwave Oven
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Kenmore 80809 Microwave Oven Logo
75 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
