Question about Mitsubishi WD-52528 52" Television
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
  • Mitsubishi Master
  • 8,457 Answers
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Posted on Apr 26, 2010
I have a 32 inch RCA LCD TV. when I play a movie, every 2=3 minutes to goes back to the blue screen, and blinks a few times then goes back to the movie. Its with every movie and I dont think it is my dvd...
Probably the Controller unit for the TV. Try hooking it up through a different connection type e.g. HDMI, component. See if that fixes the issue for the time being. If it dies then those ports you used previously are malfunctioning.
Mar 19, 2011 | Televison & Video
I need to know what the pin outs are for this stereo
See if this helps you any. http://www.the12volt.com/request/request2.asp
Jul 12, 2007 | Jensen VM9510 Car DVD Player
No sound
Make sure the speaker are plugged into the "audio out" ports. Black negative, red positive.
If a dvd players or other system is hooked up, the speaker should hook into that unit, then the unit is hooked to the auxiliary port(s), or the proper ports for each unit: ex: cd/dvd should be plugged into vd/dvd; same for vcr, game system - auxiliary is for pretty much any unit not listed on the backing of the receive - however, some units will still work while plugged into the ports other than auxiliary.
Make sure the receive is selected to the desired device.
If you simply have the speakers plugged into the speaker ports, make sure the speaker themselves are still good - try hooking them up to another source such as a a dvd player equipped with surround sound or speaker adapters that will suffice your speaker wiring.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 28, 2010 | Onkyo TX-SR606 Receiver
I have a Memorex MVD2042 DVD Player and trying to hook the dvd player to my surround sound, the receiver on my surround sound has 6 rca hookups for each speaker for the dvd player. But as far as I know the...
There is only 2 audio channels on player (L&R) Is there any audio input jacks for just the red and white (L&R) connections. Or just for main speakers?
Nov 19, 2009 | Memorex MVD2042 DVD Player
Its Radio from my junked 2000 dodge - I need to know pin inputs
yes it wil if you dont know the circuit layer of the radio wiring
Jun 25, 2009 | Kenwood KDC-MP235 CD Player
How to hook up dvd player
you dont have to use the dvd inputs if you dont want to , you could use AUX if you have it or any other unused input at the back of the amp
Jun 05, 2009 | Marantz SR7500
Hooking my dvd/vcr up to my television.
Easy Answer! connect to composite cabels to the ports underneath the words "DVD/VCR Out" for a Coaxial, use either the component ports or connect a coaxial cable from the port labled RF Out to the one on your television.
Aug 30, 2008 | Sanyo DVW-6100 DVD Player/VCR
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Aug 18, 2008 | iLO DVDR05 DVD Recorder
I need help with my tv and dvd/vcr combo
Hmmmm...I dont understand exactly what you are saying, but it sounds like your TV doesnt have RCA ports and you want to hook up a newer DVD player that uses RCA ports. If you have only a cable port (silver threads with a hole sticking out of back) on TV and RCA ports on DVD player, you have to buy a converter. You can get one at Wal-Mart for 20-30 dollars. Or you can just update your TV which it sounds like you badly need to do! :)
Dec 24, 2007 | Sanyo DVW-7200 DVD/VCR
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Mitsubishi WD-52528 52" Television Logo
206 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
