Question about Porter Cable Cable 2,500 Watt Generator with 5 HP Engine #CH250
No power output on porter cable ch250.Unit was running fine then suddenly no electric output. Any ideas?Thanks John.
  • 110 Answers
They have reset buttons usuall black push to reset
Posted on Apr 26, 2010
I am getting no Speaker output on my 2004 Yukon XL. Radio and CD player are working fine. In fact I can plug my head phones in in the rear and hear everything great. I check the fuse for the Radio AMP...
Hi Jay, Check the cables connecting the speakers. The head phones are usually driven by the pre-amp and as such won't be affected by a problem with the main amplifier. If the cable continuity is good you have a problem with the output of the amplifier. This can happen if the amp has been over loaded or with a sudden surge of power. The usual problem is with the output power transistors. Regards John
Aug 11, 2012 | Cars & Trucks
Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
Jun 13, 2012 | Porter Cable BSI550 W 5,500 Watt Generator...
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
May 11, 2011 | Porter Cable Garden
Porter cable hammer drill 987 suddenly stopped running.
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Mar 04, 2011 | Porter Cable 987 19.2 Volt Grip - To - Fit...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
Cd error message on head unit on alpine r990,this is connected to a sony cd changer,has been working fine suddenly packed up.Now when cd button pressed no indication on radio screen,boght another stacker...
Hi John, when you think about it, it could only be one of two things either the bus lead or the RCAlead as everything is in them leads to run the cd unit, So check that all leads are secure to see what happens.
Feb 05, 2010 | Alpine CDA-9885 CD Player
No electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Jun 09, 2009 | Porter Cable Electrical Supplies
Porter Cable Cable 2,500 Watt Generator with 5 HP Engine #CH250 Logo
257 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
