Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
How to change brushes in motor
I am struggling to acces the motor on my dc 05 in order that I can replace brushes
  • Dyson Master
  • 379 Answers
  • 3 more comments
  • AnnOminous Jan 08, 2011
    Excellent for dismantling the vac
    (repeat as part of message above didn't upload)
    Excellent for dismantling the vac and to get to the motor!
    But the brushes are sold naked... So the question remains:
    How do you extract the old ones from their plastic coat?
  • Samyfam
    Samyfam Jan 08, 2011
    There have been a few minor variations to the brush holder design over the years the motor has been produced, but in essence you cannot remove the brush holders from the motor.
    What you have to do is (carefully) bend open the top part of the metal sheath the brushes and springs slide up and down in, and remove the old ones from the open end.
    Fitting the new ones is then the reverse, but due to the longer length of new brushes, and new springs, it is a bit fiddly getting everything in place and holding it there whilst you bend the metal sheath back to its original position, but it can be done.
  • AnnOminous Mar 13, 2011
    Thanks Samyfam !
    I did exactly as you described and it worked perfectly.
    However as I'm not equipped to do any copper welding for the end bit of the wire, I had to deal with it in a different way from the original...
    The end of the brush wire goes through a V shaped slot on the upper copper sheath then turns at a right angle and is welded on the top of the sheath. To open the top sheath, you need to first bend open 2 small pegs that go through 2 little slots on either sides of the sheath and retain it. As the wire is longer than the original one, I guided it first through the V slot and then back through one of the holes and around and below the sheath on top of the spring before closing the whole thing again. It's not as neat as welding but the contact is as good and it's well secured.
    I'd recommend removing the wheels before reassembling. Otherwise, it's much more difficult and, especially, it makes it hard to check that the cord wheel is well aligned and positionned. If it's not so, it's impossible to have the 2 halves (lower and upper chassis) "sit snug with no gaps" as the guide says.
    All in all, it's the Paypal saga that took the longest time of the whole job..
    I also noticed that getting the parts, postage included, from UK was, at least twice cheaper than from Australia.
    Precision: Wherever I used the word 'sheath', I meant 'sheath lid' or 'cover' or 'the top part of the metal sheath' like Samyfam. Sorry! English is not my mother tongue although I do reside in Australia.
    Addition: The 2 wheels could not simply be pulled off of our DC05. Each was held by 4 nylon pegs ended like hooks (or shaped like a 1). Holding 2 adjacent 'hooks' pushed in with 2 small flat-head screwdrivers made it relatevely easy to pull the wheel off (the 2 other 'hooks' slipped in the hole naturally). This was done before reassembling the vacuum-cleaner.
Roller doesnt spin on my dc15
Hi there, it's Jack at Dyson.
If your DC15's brush bar won't rotate, it may need resetting. In order to do this, please follow the steps shown in our Support video:
If you'd like further advice after giving this a try, you can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 10, 2014 | Dyson 909592-05 DC-15 Roller Brush Beater...
Bosch 2607022999
Can't replace the brushes on t his DC motor. Have to get a replacement motor. They run about $70 at ereplacementparts.com at this writing. Direct Current Motor
Nov 19, 2013 | Bosch 2607022999 Direct-Current Motor
My dc-15 bush bar will not work
Head motor blown, will have to take it to your nearest good hoover repair centre should cost around 49 dyson will charge 73
Jan 14, 2013 | Dyson 909592-05 DC-15 Roller Brush Beater...
Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
Oct 24, 2009 | Dyson DC14 All floors Bagless Upright...
How do i fit new brushes in dyson dc 07 have the
you have got to open the motor housing that isthe black casing that surounds the motor first then the motor comes out then you can see the brushes thay come out by lifting the copper strip up gently with a screwdriver then you pull it out then put in new ones
Sep 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
We have a dyson dc 07 animal the machine was working fine then switched off after returning to the machine minutes later it wouldnt switch on, i removed on off switch cover and used a short piece of wire...
It could be the motor. I'm having to replace the brushes on my DC 05. It appears that you can only get brushes for the YDK motors in the DYSON, not the Panasonic motor. Which might be saying something about the YDK motors. What happens is that the carbon brushes wear down which is normal. However, the contact wire from the brush to its connector is set so that when the brush wears down, the wire is short enough to stop the spring etc from damaging the commutator. The end result is that you get an intermittent operation of the motor before it finally dies.
I believe all the DYSONs come with the option of both motors and you cannot really tell which motor you have until you take the thing to bits. You also cannot change motors without changing various other parts on the hoover. On my DC 05 the writing on the YDK motor tells you which one it is.
This website www. tasweb.org ,select the DC 05 option and scroll down tells you how to take the thing to bits. A search on google etc for your DC 07 may give similar results. Best of luck!
Jun 20, 2009 | Dyson DC05 Cylinder Bagless Canister...
Bissel Proheat 2x circuit board
Use this link: http://www.4cleanerfloors.co.uk/cgi-bin/product.pl?PID=1278118_amp;brand=Bissell_amp;model=_amp;part=
I had the same problem. Ordered a PCB from Bissel it took 2 weeks to arive. I fitted it, then it blew again, turned out the brush motor was short circuiting. Ordered a new motor it took 10 weeks. I have now had to order the second circuit board.
Over 3 months to get this vac fixed - my advice is - don't buy Bissels!
Jul 09, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9400 Carpet Cleaner
I assume you checked the belts to see if any cogs were stripped of of the belt. If ok, then I wuld suspect the brush roll motor, it is any inexpensive part and doesn't take much for it to fail. Undo the top so you can get to it and unhook the belt and see if it still shuts of, if it does, ten replace it, it it doesn't, then there is a problem with brush rolls or belts.
May 13, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
324 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
