Question about Summit Commercial Upright Freezer SCF-U750
Freezer temp doesn't go below 20 degrees - Summit Commercial Upright Freezer SCF-U750
  • Summit Comme... Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer temp doesn't go below 20 degrees - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 01, 2010
How lpw of a temp. Can this freezer reach..and and if only 0 degree could the thermostat temp control be changed out so it could reach les than 0 temperatures like negative 20 or so?
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
Sep 18, 2011 | Beverage-Air 44.9 cu. ft. / 1271 liter...
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Freezer temperature does not get below 10 degrees
this is something you can do now. Check this 1st:
make sure that the air vents are not blocked and that you didnt overload the freezer with food
there can be other things that will not bring the temp. below 10 (that temp. is not too bad as long as it doesnt spoil the food)
here are the possiblities:
t'stat is set too low
t'stat is not responding to zero degrees (all that means is it is shuting off the compressor too soon to reach zero)
dirty condenser
r-134a freon is a tad low (only takes like 9 oz. if lose 1 or 2 that is enough to affect performance)
the freon is the last thing to check cuase you have to call someone to do that for you...
Well hope this was helpful... check the temp often watch to see if it gets above 20 degrees cause that will spoil you food..
Mar 11, 2010 | Freezers
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Temp
jtcarlier
20 Degrees is good
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 24, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Summit Commercial Upright Freezer SCF-U750 Logo
89 people viewed this question
Top Summit Commercial Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Summit Commercial Freezer Expert? Answer questions, earn points and help others
