I have a Mac G4 computer :: some keyboard characters are scrambled: I have to press q for a, a for q, w for z, ,,, and I can use the numeric keypad only for numbers; I have since figured out some of the switches
  • foggy247 Apr 26, 2010
    Your solution (iii) is correct. We have our computer display set to darken after 15 or so minutes when the computer is inactive in order to save the hard drive and energy. To re-awaken the computer we have to click on the mouse with the screen dark and the pointer somewhere. This time we must have accidentally clicked on the language setting on the menubar from English to French. Thanks.
    President:
  • 1,194 Answers
Thanks for using Fixya.
check if these steps solve your problem :
(i) Examine your keyboard for any build-up of dust, dirt, liquids or other particles that could be causing the keys to type the wrong characters. Allow any loose dirt to fall out by inverting and shaking the keyboard lightly.
(ii) Plug your keyboard into another computer. If the keyboard works, then the port on your original computer may not be working.
(iii) Confirm that your keyboard is set to the English language. Go to your control panel and click on the "Regional and Language Options" icon. If the setting appears to be in a foreign language, change it to English/U.S.
(iv) Check if your number lock key is on. If so, depress the key to disengage it
If these steps do not work and you have spilled a fluid on your keyboard recently, have the keyboard examined by a professional service or buy a new one.
Good Luck and have a nice day.
Posted on Apr 26, 2010
My numeral key are not working[123456789 right side of key bord]
Step 1:
On some laptops it may be difficult to locate and activate the "Num Lock" key. Depending on the laptop, it may be hidden as a function where you have to press two keys. Most of the time, a laptop keyboard is just like a full desktop computer keyboard and it has a "Num Lock" key on it. Most people do not realize the "Num Lock" key is on their laptop keyboard because it barely serves a purpose without a full numeric keypad.
Press the "Num Lock" key on the laptop at the top, right of the keyboard. Press the "Num Lock" key and the "Fn" key simultaneously if the above does not work. Press "Fn" and "F11" simultaneously on the keyboard to activate the "Num Lock" function. Some laptops, like Toshiba, do have a "Num Lock" key. The shortcut for G3 Mac laptops it is "F5," and on G4 Mac laptops it is "F6."
Feb 07, 2013 | Computers & Internet
G4 power light flashes
Thank for contacting Fixya, I will be glad to assist you.
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Mac to start up.
If neither of these processes do not work, have your RAM memory checked, as this could be a factor in your G4 not booting up.
One other factor to consider, especially given consideration of the flashing light and no boot up, depending on the type of G4 mac you have, would be the power supply, which is what gives your G4 the power to boot up and function.
Hope this helps.
Regards,
-The MacTechTrainer
Jul 10, 2012 | Computers & Internet
My Powerbook G4 screen turned off because it was unplugged and the battery is no good. This has happened before and I remember there was a simple solution (some combination of buttons; Control + Option +...
It's called a Power Management Unit (PMU) Reset. Here are Apple's steps:
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the computer.
Mar 24, 2011 | Apple PowerBook G4 Mac Notebook
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
Powerbook G4 12" no video
Try this courtesy of your manufacturer
  3. Wait 5 seconds.
If that doesnt work lemme know
Feb 03, 2010 | Apple PowerBook G4 Mac Notebook
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
Mac not loading
Try resetting your pram:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Aug 28, 2009 | Apple eMac G4 Desktop
How to format an apple power G4 notebook
When the computer is off, press the C in your keyboard then turn on your computer. After that computer will boot from CD.
Regards.
Jul 10, 2009 | Apple PowerBook G4 Mac Notebook
When i stert my g4 imac,s screen was became blue
You need to reset your pram
Jul 01, 2009 | Apple iMac All-in-one - 3.06GHz Intel Core...
My mac powerbook g4 12'' wont chime or boot just comes on and screen changes colors every 2 seconds
Resetting PRAM and NVRAM
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 26, 2009 | Apple PowerBook G4 Mac Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
