Question about Magellan Maestro 5310 Car GPS Receiver
Magellan maestro 5310 is stuck on system settings screen and hard reset doesn't help. Also, tried software update and unit is not found on Microsoft XP home computer- seems there is no driver.
sids8065
  • 61 Answers
SOURCE: Magellan Maestro 3100 stuck on
you have a failed firmware install. If the rollback has not worked and is stuck on the magellan screen, it needs to be send to magellan repair center
Posted on Feb 28, 2008
AZJudy
  • 4 Answers
SOURCE: Magellan Maestro 4250
I just called Magellan.....1-800-707-9971. I got my 4250 for Christmas 2007 and never did register it. We did that over the phone and then he gave me a repair order and an address to send the unit to them. It will be fixed under warranty.....my only cost is the UPS or FED EX shipping. He said I will have it back in 7 to 10 days. OUTSTANDING service.
Mine was stuck on the blue screen.......and the pin reset did nothing.
SO......best of luck to you all......and I highly suggest calling Magellan.
Judy in Arizona
Posted on Aug 23, 2008
SOURCE: Need to update the maps
I need to update the map on my 3225 Magellan Maestro, can anyone help?
Posted on Nov 29, 2008
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Posted on Dec 07, 2008
SOURCE: magellan maestro 3100 failed update
go to Tech support at www.magellamgps.com tell them what has transpired and ask for 2.18 Update Recovery Files. This fixed my problem. Took a few email exchanges but I thought the responses were very quick.
Posted on Mar 13, 2009
My Magellan Maestro 5310 is stuck on the Magellan start up screen. the little power bar on the the bottom of screen comes up then thats it. It won;t begin to load the next screen. I have tried to reset...
Hello There, I have a Magellan myself, besides me knowing some things or two about GPS'S
Give this a try, seems to work for me and others most the time.
Try this for me to see if this works: Let me know. It needs to be rebooted. Turn off, by holding off button down. Then once it is completely off, then turn it on, BUT when you go to turn it on, keep on button depressed, all the way until it turns on and then some for about 15 seconds, now you just rebooted system. Let me know, if does work, please click on the thumbs up to showed your a happy customer. Thanks Mike
Jun 22, 2011 | Magellan Maestro 5310 Car GPS Receiver
I have had to reset my magellan maestro 5310, but now cannot get passed the system settings and system status pages. I think I have to download something to get it back up and running but not sure where to...
Hi tedmare1
you can download the 4.72 update for your 5310 HERE but follow the directions to the
letter or it will render it inoperable...read all the instructions aftrer downloading and before you
run the update.
make sure either the battery is fully charged, or you have it plugged in to the home charger
NOTE: the usb cord will not charge a magellan 5310, so you need to use the home charger or
fully charge it woth the car charger before starting...if the download is interupted for any reason,
the update will fail and the 5310 will not fully boot.
you might have to register your 5310 with the site before downloading (you used to ) but maybe not since they changed their site within the last few days.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Nov 15, 2010 | Magellan Maestro 5310 Car GPS Receiver
I was trying to update my software and I accidently connected the unit to the computer before I was supposed to. Now the unit is frozen on the Magellan screen. If I connect it to the computer it just...
Look in your manual on how to do a hard reset. Usually is holding the power button/slide on while resetting. That can get it out of loops. This is a more brute force reset that just using the reset button
If that doesn;t work you should talk to magellan tech support. They are quite helpfull and may have some differant way to reset things. And at worse will be able to tell you if it is time to send it in.
Mar 30, 2010 | Magellan Maestro 5310 Car GPS Receiver
My 5310 goes to the "System Settings"
not sure how you tried the rest, but try turning the 5310 on and then hold the power button for 15 seconds, then start it again... if that fails, turn it on and press and hold the reset for 15 seconds.
if it works, try and update it again!
if neither of those work, its possible the digitizer (touch part of the screen) is out on it.
if its under warranty, send it back. this is a know problem with this model but most times it will reset and work fine.
bill
Sep 28, 2009 | Magellan Maestro 4040 GPS Receiver
My Maestro 3225 is stuck on the system settings
if your lucky, all it will need is a reset. start the unit and using a paper clip, insert it in the small hole on the side. if that fails, try the update using the Magellan link below...follow the update directions carefully. you must register your unit on the magellan site to download the update.
if neither solution works, id say the digitizer is bad (the touch screen) but the update normally cures this problem!
let me know if you need further help!
Aug 29, 2009 | Magellan Maestro 3140 GPS Devices
I have a magellan maestro 5310 which I have had about 4
press and hold the power button for up to 10 seconds. that should reset it. after you do that, go HERE and download and install the latest update for your 5310
bill
Aug 26, 2009 | Magellan Maestro 5310 Car GPS Receiver
Hi My Magellan Maestro powers up with the Magellan screen and the bar scrolls but thats all it does? Carl Lucas Aberdeen MD
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Aug 03, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan GPS stucked in the setting mode and there is no way out. Need some help.
hi tchen2005, try the hard reset first. its the little hole on the side of the unit. while unit is off, use a paperclip the reset the unit. if that does nothing to fix the problem, get the latest update. Magellan has two different updates for the 4040, follow the directions to make sure you get the right one. if you still have the same problem after you install the update, the digitizer is probably broken. hopefully that is not the case, because the digitizer is part of the screen and cant be replaced without replacing the screen unless your very skilled with soldering micro electronics.
if you need further help, just reply to this post.
Jul 23, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
There is a RESET button on the bottom of the unit on the left side
Nov 22, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 5310 Car GPS Receiver Logo
391 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
