Hi, I have a whole-house heavy duty water filtration unit from GE. When I go to replace the filter, it and the entire inside of the filter system is coated with a purplish slimy substance that stinks. I try to clean the unit the best I can, but it just reappears and makes the water smell bad. What is it, and how can I fully clean the filter system so it does not return?! Thanks, Jerry [email protected]
  • 13 Answers
This could be some form of a silt type substance. I would recommend a sediment pre-filter in front of the GE System. Possibly a Rusco Spin Down Filter System. This is a clear housing and a mesh filter that is washable. You would want to use a 250mesh filter.
Recomended Product Example:
http://www.freshwatersystems.com/c-204-rusco-spin-down-filters-w-pe-ss-screens.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Posted on Apr 28, 2009
    Sergeant:
  • 351 Answers
Do you use liquid soap or fabric softner,if so change to small amount of powder.try filling the machine with really hot water and let it soak for an hour or so.hope this helps.
Posted on Mar 26, 2008
SOURCE:
Are whole house inline water filtration systems expensive?
House filtration systems are pretty pricey they run in the several hundreds dollars, and then replacement filters are in closer to $20 and they only last a few months. If you don't need a filter on every faucet you can install individual filters under the sinks in your kitchen.
Sep 10, 2013 | Water Dispensing & Filtration
What are the methods for water purification?
Purification methods can be divided up into settling of suspended matter, physical or chemical treatment of colloids and biological treatment.
Aug 23, 2012 | Brita Camping, Backpacking & Hiking
Ge smartwater wholehouse waterfilter main housing failed flooded house
Why did it fail? How did it fail? Was it the plumbing that failed? Replace it with a Pentair filter housing, 10" housing, 20" housing or Big Blue housing and make sure it is plumbed in properly. It is very unusual for a filter housing to fail unless it freezes up.
RJ
Apr 18, 2011 | General Electric GE SmartWater Household...
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Nov 10, 2010 | General Electric GE SmartWater Household...
I have a whole house water filter that uses a 30 micron FXHSC filter. the last two filters have come apart and sent fiber through the water lines in the house
I would shop around for a different water filter supplier...there is no reason ofr that happening unless you are not changing the filters regularly...like once a month...
most filters are a standard size and it should be easy to get them somewhere else...
heatman101
Aug 13, 2010 | General Electric GE SmartWater Household...
The red pressure relief button on my GE Smartwater GXWH35F whole house water filter system doesn't seem to be relieving pressure. As a result I cannot turn the filter cartridge in order to replace the...
To replace the filter cartridge. Do the following;
1. Assuming that you have a pump in your water filter
system, shut it off.
2 Close the intake valve before your filter system.
3.To relieve the pressure, open the faucet after your
filter system. Any of your faucet for that matter.
4.Once the pressure is relieved, you can of course
replace the the filter cartridge.
Nov 26, 2009 | General Electric GE SmartWater Household...
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
Apr 27, 2009 | General Electric GE SmartWater Household...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
