Question about Cameras
Dark picture I have a picture of my wife which i had taken inside the chapel.it is so dark the background is the same color of her skin.How can i separate the color of her skin and the wood in the background,please help.
    Problem Solver:
  • 5 Answers
Try using adobe photo shop...
Posted on Mar 24, 2008
Test chart tamrom
Front and back focus tests are good to run. You need to do it for each prime lens (fixed focal length) you have, and at your favorite focal lengths for wide angle zoom lenses too. That means on this 17-50, you would pick wide 17mm and zoomed in 50mm, and several others between. If you pick 25mm and 35mm to test, you would end up with 4 potentially different adjustments. These would apply only at 17, 25, 35 & 50mm. If you shoot at say 20mm focal length, and assume it's the same as 17 or even 25mm, you may be wrong. Too much back or forward focusing is a problem with the camera body usually - not the lens.
I'd pay attention to the lens. Look for cloudiness on the edges of the glass, scratches and fungus on glass, wetness or oil on the aperture blades, specs of dust inside the lens, etc. All of these things take away value from the lens, as they can adversely affect the image or shorten the useful life of the lens. You check these things by looking directly through the lens (not on the camera) and look at a dark background - then a light colored background to help show dirt and dust inside.
The only other thing is to look at actual images taken with the lens. Enlarge the pictures to 100% or more. Look for fuzzy edges, purple fringe edges, colors. You will see all of these issues the more you zoom in. You have to decide what it acceptable to you and what is not. Expensive lenses capture great color, are very sharp and have minimal purple fringing on hard edges (high contrast areas) in pictures.
Jan 30, 2012 | Tamron Test Chart For Tamron Af 28200mm...
COLORS BLEED, FOR EXAMPLE, THE BACKGROUND IN A GOLF GAME IS VERY BLURRY. sKIN TONES ARE OVERLY DARK
You may have heat relate problem with the T-CON (LCD controller). Try cooling it with small fan blowing in the back with the back cover off. Be real careful, high voltage inside.
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Apr 03, 2010 | Westinghouse LTV-32w3 HD Television
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
I have a 42" Lg lb1dra model lcd 1080p model that is giving me color troubles. It all began by having some lines interfering with the pictures. I phoned my satellite provider and they sent a signal to zap...
hi..there is some problem in your video ciruit
board.only when you have problem with the video
board you willl come across such type of problem.
check it out..
thank u..
rate me..
Feb 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Hello Fixya, Thanks for being available in the Net!!! I have a mitsubishi tv model #ws-55809 and the picture is funky.... It's like it's cartooned. The words are fuzzy a bit and so is the skin...
Sounds like a loss of picture resolution. There is a circuit board in your TV that determines the type of signal (HD or standard definition) The video signal (picture signal) is routed thru this board. Call a local Mitsubishi servicer and get a price on replacement. It may cost more than its worth.
michtech
Feb 12, 2009 | Televison & Video
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
INDOOR PICTURES ARE TOO DARK
try using the night shot it will go slower but it works well for dark pleases
Dec 17, 2006 | Aiptek MPVR Digital Camera
Cameras Logo
75 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
