Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
I plugged in the wrong power supply into the harddrive and now with the correct one the power sullpy light is dim. is there a protection device or a way to remove info from drive?
  • 119 Answers
Most of them have a protective circuit. You might have to send it back for repair. Hope its still under warranty.
Posted on Apr 26, 2010
Headlights won't come on sometimes weather on auto or manual.The dims lights have always worked .I replaced a bulb on the dim and the high beams stopped working. That has been a while back.Two days ago,the...
Yes sounds like the sensor.
Make sure you install the correct bulb type (voltage and wattage) to replace the old one.
Also check all your wiring and plugs to make sure you have good reliable electrical connections, they need to be tight, free from obvious dirt and corrosion.
If you have a multimeter do a Continuity test on the wiring
Note: When testing the circuit continuity, be sure that the power of the circuit has been shut down and all capacitors have been discharged fully. (this is to protect your device and in high voltages to protect you)
This should help you identify if you have a wiring issue.
Feb 07, 2014 | 2005 Chevrolet Colorado
Can not get my tail lights to work onk 1989 gmc truc
The front park lights work correct? If the front park lights work than there is not a problem with the light switch since the brown wire from the switch supplies power to the front park lights, front side markers, and the rear taillights. There should be twelve volts on the brown wire from the headlight switch with the connector plugged in and the park lights turned on. If this is true that there is a problem with the wiring to the back of the vehicle. A thorough inspection of the harness should reveal the problem. The dim break and blinkers support the above. High resistance also know as corrosion, in the wires or connections would cause this problem.
Aug 24, 2012 | 1989 GMC Sierra
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
The power supply light is flashing and my computer won't start up. No fan, nothing. I disconnected the power to the mother board and the light burned solid when plugged in. I have switched the watts...
Bad Power Supply.
Weak voltage power rail, or rails.
{There are three voltage power rails.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail}
The flashing Green LED light is one direct indication of this for HP computers.
Usually there is at least enough power to light LED lights, and spin fans, but your Power Supply doesn't even have that much power.
1) All of the LED lights on at once use less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts of power
3) A typical Processor can use 51 to 125 Watts of power.
Depends on what Processor it is.
The HP Pavilion A847C desktop computer has an ATX power supply, with a maximum rated wattage of 250 Watts.
The ATX form factor for a Power Supply refers to it's case size, for one.
5-1/2 inches Long, 3-1/2 inches Tall, and 6 inches Wide
The common type of Power Supply used in over 80 percent of PC computers out there, and readily available all over.
HP Support > Pavilion a847c desktop computer > Main support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=448706&lc=en&cc=us&dlc=en&submit.y=7&submit.x=5&lang=en&cc=us
Click on Product information in the list
Now click on Product specifications
Finally click on > Motherboard Specifications, PTGD1-LA (Goldfish )
Scroll the page down to view the motherboard illustration and photo.
The replacement Power Supply has to have,
A) A 24-pin ATX main power cable.
In the motherboard photo, view the Ram Memory slots. The long Blue, and Black slots.
To the right of the bottom corner of the Black ram slot (Slot 4) is a whitish connector.
Two columns of 12 socket holes.
This is where the 24-pin ATX main power cable plugs into.
(ATX Power Connector in the motherboard illustration)
Typical 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
NOTE the Lock Clip on the side of the connector.
B) 4-pin ATX +12 Volt power cable.
At the bottom Left corner of the Processor socket is a whitish square connector.
4 socket holes.
This is where the 4-pin ATX +12 Volt power cable plugs into.
(ATX12V in the motherboard illustration)
Typical 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
{The top of the Lock Clip is squeezed in to release it, and is held while the power cable is removed.
Same for the 24-pin ATX main power cable's connector}
C) SATA power cable.
Used for the SATA harddrive
The SATA power cable has 15 pins, and is the longer connector.
The SATA data cable has 7 pins, and is the shorter connector.
IF, the SATA harddrive has provisions for plugging in a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY USE the SATA power cable.
Otherwise you will burn up the SATA harddrive.
The SATA power cable plugs into the SATA harddrive.
One end of the SATA data cable plugs into the motherboard, and the other end plugs into the SATA harddrive.
Below the ram slots in the bottom Right corner are the SATA headers on the motherboard, that the SATA harddrive plugs into.
The Blue, Orange, Black and White connectors.
Of course the SATA harddrive only plugs into one of them.
Looking at the motherboard illustration you will see they are numbered.
SATA 1, SATA 2, SATA 3, and SATA 4.
IT DOESN'T MATTER which one you plug your harddrive into. (Or any SATA device)
That's the beauty of SATA.
BIOS will find the harddrive.
But for you, it will be easier to keep track of where the SATA harddrive is plugged in, if you just use SATA 1.
Typical SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
D) 4-pin standard Peripheral power cable.
Commonly referred to as Molex. (Misnomer)
Used for optical drives, Fans, and other associated hardware.
Typical 4-pin standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
E) 4-pin Small Peripheral power cable.
Used to be commonly used for a Floppy Drive.
For your computer it provides power to the Memory Card Reader.
Typical 4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Watch disconnecting, and connecting this connector. You can bend the pins very easily.
SAFETY
WATCH your fingers as the pins are QUITE SHARP!
All of the power cables listed above are standard for today's Power Supply's.
About the Wattage.
A computer ONLY uses the power it needs, and NO more.
If you put a 10,000 Watt power supply in, and the computer only needed 100 watts for what it is doing, it will ONLY use 100 watts.
To wit, if you install a Power Supply with more Wattage than 250 Watts, it will NOT hurt your computer.
If you need guidance in replacing your Power Supply, or recommendations for a Power Supply, please state in a Comment.
Regards,
joecoolvette
(Apologize for being so lengthy)
Nov 24, 2010 | HP PAVILION A847C Intel Pentium 540 HT...
TV won't power on
ya u repair ur smps power sullpy soon ,nither ur power supply gone damage
Jun 02, 2010 | Sampo PME-42S7 42 in. Plasma EDTV
PC fans turn on but it doesnt do anything else
HI. check the hard drive pin plug that connects to the main power supply unit. make sure it is connected properly. if the connections are correct, this will confirm that the motherboard has failed.
Oct 03, 2009 | Computers & Internet
UPS does not supply power to equipment after power trip
Some of the less expensive UPS devices have two sets of plugs.  One set provides backup power and the other set only provides surge protection.  You need to ensure that the devices for which you want backup power are plugged into the correct outlets on the UPS.
Apr 20, 2009 | Computers & Internet
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
No power, power supply & motherboard green light blinking
I had the same exact problem for the same exact reason. Plug the power cable into the back. Open up the side of the case and unplug all the wires that the power supply plugs into. The motherboard, harddrive, cd & dvd drives, everything. wait about 10 minutes and plug them back in, plugging the BIG cable that connects to the motherboard back in LAST. This will make the light go from blinking to solid. I think it is a safety? to protect the motherboard from damage.
Nov 01, 2007 | Sony VAIO VGC-RB42G PC Desktop
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
67 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
