Only starts if I jump solinoid with screwdrivers. is it the ignition switch, pto switch, or any other saftey switches? how can I check?
Beings you can get to the solenoid I would check it first. There is a small post (not battery or starter), touch a jumper wire from battery to this post. Then with a test light check the wire to that post w/key in start position (remember you must be in regular start condition for this test). If no light, you can only go to each switch one at a time and bypass then try to start again. Not sure how many there are.
