Question about Panasonic Lands Phones
My Panasonic dual phone system Model KX TG5240CM is not sending or receiving calls - there is no dial tone. Any suggestions?
SOURCE:
  • 201 Answers
SOURCE: Changing an ordinary phone to a PABX Phone
The KX-T7730 is a proprietary phone that needs to be connected to a Panasonic phone system. It sounds like you took the phone home and are trying to use the special features. These phones are "dumb terminals" everything is performed (and stored) at the control unit.
Posted on Sep 13, 2007
SOURCE: Dial Tone but won't call out.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
Posted on Jan 06, 2009
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
SOURCE: I HAVE A PANASONIC PHONE MODEL KX-TGA641C AND ALL
Remove all power (wall and batteries). Ensure that the phone line is active and properly connected. Did they used to work? If so, check line conditions. If not, return for exchange.
Posted on Nov 29, 2009
SOURCE: Panasonic KX-TGA601CB cordless phone Was working
phone says move closer to base
Posted on Jan 28, 2010
I have a KX-T7130 phone system with intercom. for the last 4 weeks, every phone will ring once and then the call gets hung up before I can answer it. I can use every phone to call out, but just can't...
Most likely NOT your phone system (anonymous)
Neither is it likely accidental...
What it sounds like you are getting is a "ring splash"
It is a token ring to let you know a call was forwarded...
My best suggestion would be to call YOUR OWN
number and find out who has been getting your call...
Or at least what kind of TREATMENT your callers have been getting...
Since this is a GLOBAL SITE... I would suggest you consult
your service PROVIDER.. for the appropriate enable & cancel CALL FORWARDING.
BELL-SYSTEM Codes to invoke and cancel
Codes: *72 and *73: respectively
Forward... *72 = ("star, seven, two")
*72 (wait a second dial tone) dial tone + (forward number)...
If the call is answered the FORWARD is complete...
(confirmation)
Else
Repeat the SAME dialing PROCESS
(OK: indicated by two stutter dial tones followed by dial tone).
((confirmation)).
Cancel FORWARD...
*73: To CANCEL forwarding... *73 = ("star, seven, three")
(again OK... Success is indicated by two stutter dial tones followed by dial tone (yet another confirmation))...
Hope this helps...
https://en.wikipedia.org/wiki/Carnac_the_Magnificent Carnac the Magnificent
May 24, 2017 | Panasonic KX-T7130 Corded Phone
Our KX-T7735 phone system is not working, yet our phone service is live. Is there a code we need to unlock?
Have you tried pushing to CO button and then dialing out?? Otherwise unplug the phone from the wall and power, pull batteries and wait half hour and reconnect.
Nov 13, 2013 | Panasonic KX-T7735 Corded Phone
Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
Apr 10, 2012 | Panasonic Lands Phones
Is it possible to have the kx-t7730 work on DTMF? My operator says thats the only way I can access some added services
It will, but you may have it programmed to not send DTMF in SYSTEM programming. Since the 7730 is backward compatible to every KX-T system Panasonic made, you need to post a model number of they phone system to get instructions.
Are you in a rotary dial phone system area? There are 3 ways to program dialing, rotary, tone, and suppressed. The 3rd one will ONLY send pulse dial and inhibits the audio. It may be that you can press # and force DTMF. In the last 20 years or so, we have never had to worry about that as our phone companies no longer charge for "touch tone".
Carl
Dec 10, 2009 | Panasonic KX-T7730 Corded Phone
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
    Panasonic KX-FL511 cannot receive faxes but can send
    check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
    Thank You,
    Mikey
    Thank You,
    Mikey
    Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
    Lands Phones Logo
    Top Panasonic Lands Phones Experts
    Ekse
    martin hogg
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
