Question about Dell Latitude D610 Notebook
My Dell D610 starts and operates properly, but completely locks up after about 10-15 minutes. I let it cool, and it will start again. I have checked and the fan does run. I cleaned the area around the fan and heat synk. Any ideas?
  • 1 more comment
  • gcoale0847 Apr 27, 2010
    Thanks. I followed your suggestion. What should the temps be? I changed the fan speed to high. It seems better, but when cpu use went to 80-90+% it locked up after a while. Just doing email, etc, the cpu temp runs 38-40C. GPU around the same. When cpu usage goes up, temp rises to 60+.
    Thanks again. Converted to Farenheit. Running around 91 under light load. Checked all the programs running at start up. Looks like alot. I do not know what they all are. I am far from a computer expert! I don't want to delete some that are needed. I saw an option of choosing Diagnostic Startup. Should I try that?
    Thanks for your patience. My email is: gcoale0847@yahoo.com
    Sergeant:
  • 180 Answers
You can download this to see if it is getting really hot first.
http://www.diefer.de/software/i8kfangui31.exe
after you install it you can go into the settings and turn on the monitors for the cpu, gpu, ram, and sometimes the hard drive. you can turn on the fan monitors too to make sure they are working. you can control the fans as well. i use it on all my dell laptops. it its not freezing becuse of overheating then it might be the hard drive or you might need to reinstall windows
Posted on Apr 26, 2010
  • peeface
    peeface Apr 27, 2010
    i always switch to farenheit so i dont know the celsius degrees. mine usually runs around 80 or so just sitting and 100 or a little higher when doing a few things. if mine is running hot a lot i go into the task maneger and see whats running and what i can get rid of. right click on the task bar at the bottom of your desktop and choose task manager or ctrl alt del usually does it. when i am in task manager i usually click on user name so it puts everything in order so i can see what my user name starts. you can try starting in safe mode and seeing if it still shuts off. safe mode starts minimal things so you can check the task manager there too to see whats running. you might have to manually start the fan program so you can see what temp it runs at in safe mode. after you look through the task manager and you know what doesnt need to be running, you can go to start>run and type in msconfig and click ok and then go to the startup tab and that shows you what starts up everytime the computer starts. if you dont need it, you can un check it. if you wanna comment back with some of the programs running i can try to help you some more.
  • peeface
    i think diagnostic startup is almost just like safe mode. if you want to type them on here i can try to help. i know thats a lot to type. you can try toing like a couple screenshots so i can see all thats there. when i do that i push the print screen button and then paste it into paint and crop it so it just has the startup window so it is bigger. or if you wanna give me your email so we can try to do it over email instead of on here. up to you
My dell latitude D610 laptop gets heated up after a few minutes I the start the laptop and eventually shuts down.
  • There is a possibility that the fan of your laptop is not working. Make sure when you power on the laptop the fan is running. And if the fan is not working replace it so that your laptop will not heat up and it will not shut down.
Feel free to reply this solution if you have further questions. Thank you.
Feb 14, 2011 | Dell Latitude D600 Notebook
I have a Dell Latitude D610. It acts like Windows XP is starting then goes to the blue screen with the massage "Stop: coooo218 {Registry File Failure} The registery cannot load the hive (file);...
Follow this instructions http://support.microsoft.com/kb/822705 to repair the Operating system and retrieve your files. Or you can just reinstall the Operating system to make things easier if you dont have any important files in your computer.
Dec 29, 2010 | Dell Latitude D610 Notebook
My dell laptop D610 is dead completly and doesn't want to start.
I found this hope it helps
http://en.kioskea.net/forum/affich-43478-dell-d610-wont-power-up
Dec 14, 2010 | Dell Latitude D610 Notebook
Dell latidude d610 wont start properly
Can you select "safe mode" from the boot menu? As much as I hate to recommend it, I think you should wipe the hard drive and reinstall Windows (I hope you backed up everything of value on your computer). If you can't successfully reinstall the operating system, then I'd say, in all likelihood, you have a defective hard drive which would need to be replaced.
Feb 11, 2010 | Dell Latitude D610 Notebook
2000chev1500havetoflushheatercoreevery2monstogetheat
I recommend this procedure, starting with a cold engine: Remove the radiator cap, remove the thermostat, re-install the thermostat housing, leave the radiator cap off, start engine and idle for not less than fifteen minutes, then turn engine off. Allow engine and radiator to cool completely, then open the petcock at the bottom of the radiator, and drain completely (there will still be some coolant/water in the system).
Remove the thermostat housing again, then remove the old water pump and install a new water pump, replace the thermostat with a new one rated at 195 degrees, and be sure to install it in the proper direction. Fill radiator with water only (you don't want to waste money on antifreeze until you are sure you have heat), leave radiator cap off, start engine and let it come to operating temperature, not less than fifteen minutes. Turn engine off, and let cool compltely. Fill radiator with water only, install radiator cap, and restart vehicle. Let come to operating temperature again, not less than fifteen minutes, turn off. Let cool completely, drain radiator again if your truck got proper heat in cabin, then refill with the proper mixture of water/antifreeze. This sounds like a lot of repetition, but this will flush your entire system, boost your water pressure, and properly regulate your engine temperature. If the problem repeats in your two month window, have the radiator professionally serviced and the heater core will probably have to be replaced.
Always use the proper type and amount of anitfreeze!
Jan 28, 2010 | 2000 Chevrolet Silverado
My dell latitude d610 tries to load windows, but doesn't complete
The operating system may be corrupted and needs reinstalling or repairing. The manual is available online at dell website. But I doubt anything in the manual will help with this problem. Consult a PC Tech to help you rectify the problem. It cannnot be done through this forum.
Jul 27, 2009 | Dell Latitude D610 Notebook
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
Dell d610 start only a few second then its going off
try to boot in safemode, if you cant then you have to reload or repair your operating system
Jun 11, 2008 | Computers & Internet
Dell Latitude D610 Notebook Logo
488 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
