Question about Mitsubishi WS-55515 55" Rear Projection HDTV
Blinking light mitsu ws-55515 rptv
I turn the tv on and fuzzy static screen somes on. The tv wont do anything. Does not respond to any buttons. It tehn turns off after about 30 seconds and the green light next to the power button starts blinking. Then goes out after about 30 seconds. I tried resetting it and unplugging it. same thing. Started after the cox cable guy came to fix our weak signal problem. We were not getting some hd channels.
  • jor-g Mar 24, 2008
    It blinks a 12 code. one blink...a pause...then two blinks.
Repair man came out here. swapped out the DM and still didnt work. So after checking a few voltages(standby...etc) he came to the conclusion that the E2P PCB is at fault. but may still need the DM. For the Dm he was going to charge me like $500 total. Now he is charging me about $255. he charged me 140 for service call and 225(labor including cleaning and basic calib.) plus $30 parts. The 140 goes towards the repair bill which ends up to $255 coming out of my pocket...does that sound reasonable???
Posted on Mar 26, 2008
  • Mitsubishi Master
  • 8,617 Answers
If the set is shutting down it should blink a code. Try pushing in the menu and input buttons on the set both at the same time and hold them in for 8 seconds to see if the self diagnosis will falsh a two digit code. Let me know what happens
Posted on Mar 24, 2008
  • Sonny Berry
    Sonny Berry Mar 24, 2008
    a 12 code means the TV isnt shutting down for protective purposes. You will no doubt need a service manual to check the power supplies as its probably something real minor in the start up or stand by voltages that is preventing the set from starting. I have a link where you can get the service manual and they provide free support to heklp you diagnose and repair your TV with the purchase of the manual. If you would like the link let me know. They email the service manual after purchase.
I have a Mitsubishi WS-55515 that was unplugged, when It's plugged back in there is power but no picture and green light flashes then the power goes off. For reading other posts I believe it is th
if set has been unplugged plug it in and try to turn on===when power light goes off in seconds:
on the front of the set press and hold both the menu and input buttons for five seconds and release both.
power light will blink a two digit error code like 2 blinks, 2 blinks pause and repeat it several times.
what error code do you find?
Apr 11, 2012 | Televison & Video
I have a mitsubishi WS-55515 . the green light blinks continously and it doesn't respond to any thing
This unit s common problem is a fluid leak on the chasey from one or more of the tubes it leaks on the chasey maybe only one or two drops but after a period of time it causes a corrosion on the chasey and things like this happen you have to get a lamp or flash light and look in the tv to see if this is happening be surre to unplug tv
May 19, 2010 | Mitsubishi WS-55515 55" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55515 light blinking
Sounds like the remote is not programed correctly or the input sources have been changed.
Call the cable company and complain that it worked before they came and shoud work afterwards.
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Ws-55515
You will need to reset the Netcommand and tuner2.gif settings in the set.
The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half.
Then, reprogram the Netcommand settings.
This should solve your problem.
If you need more information, then, reply to this post and I will respond.
Dec 15, 2007 | Mitsubishi WS-55515 55" Rear Projection...
MODLE NUMBER WS-55511
Missing voltage = open fuse in power supply?? soldered-in
pico fuse?
Does light blink continuos up front?
Can you hit power again with same result or must unplug/plug
AC cord??
Oct 24, 2007 | Mitsubishi WS-55515 55" Rear Projection...
WS-55515 Loss of sound and HD blue screen
First check set for problems by:This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Self-diagnosis error 2-3 indicating deflection failure. Check for shorted or leaky Q5A37 part # 260P818050 located on PCB-Main. If found defective replace only the transistor instead of the Main PCB.
Sep 09, 2007 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi WS-55515 55" Rear Projection HDTV Logo
182 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
