Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
At startup, no beeps, no display? - Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
  • 75 Answers
- clean up the memory than mount again
- check the vga cable or vga card
- change the transistor near the power supply socket
Posted on Apr 26, 2010
Hi my power first t960 treadmill stops working. it turn's on. startup beeps are ok. display turn's on and showing regular digits. but non of keys working and consul dos not response to any key. thanks
Check the cable from console to motor control board. It would be a detachable connector on both ends. Try removing and reconnecting it. Sometime such problems can occur because of the bad contacts of connectors.Please remember to remove the power before attempting any service inside treadmill.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Exercise & Fitness
Sony vaio beeps on startup then beeps once every three seconds
Could be a problem with the RAM. You can do a boot-up RAM test with a CD-ROM or USB stick using Memtest
Memtest86 Advanced Memory Diagnostic Tool
Jan 11, 2014 | HP Compaq DC5800 Small Form Factor PC...
My Dell Poweredge 1550 won't connect to the screen. It also constantly beeps upon startup
Is it in a 1, 3, 2 beep pattern (beep....beep, beep, beep........beep, beep)? If so, the memory is either not seated well or may be bad. Try reseating your memory. If it continues, try with one stick at a time just to see if it will boot up with a display.
Thanks,
--Brian
Nov 02, 2013 | Dell PowerEdge Computers & Internet
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
No display
Do you get a beep at startup? A single beep means it passed initial diagnostics.
Sep 18, 2008 | Intel Desktop Board D815EPFV Motherboard
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
135 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
