Question about Saniflo & Saniplus& Macerator Pump
My saniflo plus system keeps blocking and not draining water. Is there a simple solution? Does it need replacing or can it be fixed? Its about 3 years old
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
Might need a new pump inside or a switch.
Posted on Apr 27, 2010
Saniflo - macerator not working, toilet blocked and fuse blows instantly
You probably have a dead short in the line. That should fix the problem.
Jan 30, 2013 | Saniflo & Saniplus& Macerator Pump
Pump continues to work long after toilet has been flushed as if the saniflo pump is unable to pump all the water out at once like it used to. There is no clog in the vent line, and only a partial block if...
I know nothing about the Saniflo system but I suggest you check in the supplied literature if any routine maintenance is recommended and if so I think it would be wise to do that before looking for further explanations (problems).
Nov 07, 2017 | Saniflo SaniGrind Grinder Pump (Toilet...
My saniflo plus is making a humming noise but not draining any water away the sink has filled with water and so has the toilet and shower tray help
My saniflo-plus system is about 12 years old..recently it stopped draining the toilet, etc. I pulled the cover off the pump and checked for blockage and spun the cutter blades...The motor just hums....do I need to replace the entire encased pump assembly?? Help
Jul 07, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
I thought my macerator toilet must be blocked as it wasn't emptying in the bowl and when I flushed again the water (and waste) filled more into the bowl and leaked out of the top of the macerator spilling...
Typical saniflo costs about 500 quid incl vat from plumbase, prices vary according to what you need it to do.
It keeps making noise becasue the pump is still trying to get rid of the water inside.
it can't get rid of the water most likely because their is a blockage in the waste water pipe.
if possible follow where the waste pipe runs to. if it goes in to a loft or somewhere else VERY COLD there is a good chance that it has frozen somewhere along the pipe.
If you are tying to pump the toilet waste vertically (upwards) then as soon as you turn the power off to the saniflo, the waste will fall back down and in to the toilet - or over the top in your case, sorry!
You might want to accept the inevitable and get a bucket and start removing the waste water from the bowl. Make sure that you have rubber gloves and I suggest goggles and something protecting your mouth - in case you get splashed.
Easiest solution, is to remove the excess waste water, turn off the saniflo, pour some bleach in to the toilet bowl, then cover the bown securley with cling film to keep the rank smell at bay.
Other wise, start tring to follopw the waste water pipe and warm it up, either by directly or indirectly (warm air gun) or by warming the area around it.
Personall;y i am using the easy option. the cold werather won't last forever, but can you use a toilet elsewhere in the meantime.
In the meantime, Saniflo claim about 15 years as the lifespan, but i have never know a saniflo to make it past 3! they are not ideal, but may be your only option.
consider whether you could get a proper toilet waste pipe put in, as it WILL save money in the long run...
Hope this helps a little bit.
Mark
Jan 08, 2010 | Saniflo & Saniplus& Macerator Pump
My saniflo will not pump out and water is backing up in the sink
Probably blocked on the intake pipework. You'll need to get the Saniflo out, clean out all the build up from the inside and try again. It is probably an idea to try and clean the pipes as well.
Not really advisable to use Mr.Muscle or other drain cleaners on the Saniflo range as it can eat the seals.
Good luck
Jan 04, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Sewer gas smell
blocked drain outside you will need to get somone in to flush it out and the problem will be solved
Dec 31, 2009 | Saniflo Sanibest Grinder Pump Only 013
It is blocked how do i unblock it
Turn off electricity to saniflo.Turn off water to toilet (normally an inline valve). Empty toilet bowl and cistern of water. Remove toilet, cistern. Disconnect inlet pipes to saniflo (careful as backed up water will flow out!).
Take out Saniflo (outside is normally good). Open up top with star driver and use a flat blade for the plastic retaining flaps.Be sure to wear rubber gloves to keep out germs from cuts etc on your hands.
Cover mains cables with plastic food bag and tape up. Use a solution of bleach / warm water, fill up the sanifo and leave for a while. Swish around and empty into a drain etc. I also use a hosepipe to make sure I get it really clean (esp under motor and float switch). Also check inlet pipe flappy bit and the actual pipes that connect to the saniflo
Good luck
Dec 19, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
I fitted a saniflo plus about 3 months ago engineer been out 5 times even changed unit last engineer said it was toilet paper stuck in tiny hole at bottom of motor he said it was due to not flushing...
This could be a problem with the capacitor which drives the blade and impeller. If it goes bad it will pump water only but when solids are flushed, it will jam the blade and cause it not to spin. You may have to replace the capacitor/condenser.
Nov 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
The water from the loo and shower is rising & not going down
The outlet is blocked , get an engineer in to fix it pronto
Aug 24, 2009 | Saniflo Home
Saniflo keeps blocking?
do you have cess pool or city drain.
if it is cess pool , you need to pump it out. IT IS FULL. if it is city, you need a plumber to check the drain to the city line.
Mar 08, 2009 | Home
Saniflo & Saniplus& Macerator Pump  Logo
360 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
