Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Refrigerator portion is not keeping up to temp just holding @ 55
Freezer is working just fine but refrigerator is holding @ 55 degree's no matter what I set the frig @? Is there a motorized valve that let's cold air into the frig? maybe that's not working? Thank you
  • Kenmore Master
  • 43,501 Answers
Posted on Apr 27, 2010
The freezer is fine steady at 0, but the refrigerator temperature keeps rising currently at 67 degrees.
Check the freezer make sure you do not have frost build up. Defrost problems choke out the air flow and if it happens the refrigerator will not cool.
Sep 15, 2015 | Frigidaire FGHS2342LF Gallery 22.6 Cu. Ft....
Refrigerator runs but does not cool properly. Temp in freezer is 34 degrees, temp in refrigerator top is 70 degrees, and at bottom is 55 degrees.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | GE GSS22IFR Side by Side Refrigerator
Fridge side works fine freezer side keeps running no matter were you set the temp -10 -20 degrees sounds like the fridge is running all the time
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 06, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
Refrigerator Model TFX22KRDA. The evaporator located in the freezer ices over and loses cooling capacity. When turned off and the ice is removed, the freezer and refrigerator both work fine for a few weeks...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | GE Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
Top portion offreezer is warm bottom is cold
Sounds like the defrost heater is bad . Part number WR51X10055 . You will need to remove the 2 or 4 screws , holding the lower portion of the inside rear freezer panel . The heater , is attached to the bottom of the coils , held on by 2 screws . You should also replace the defrost thermostat , Part number WR50X10068 . This is the 1 " cylinder , clipped to the top of the coils , with a blue and pink wire attached to it . This bimetal (defrost thermostat) , cuts the heater off , when/if the temp behind the panel gets to 140 degrees , therefore , keeping the food from defrosting .
Oct 22, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
143 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
