Question about Canon imageRUNNER C3200 Copier
I have a Konica 7145. It has error code
I have a Konica 7145. It has error code F-36-1. I tried cutting the power completely and restart a number of times, but the code stays all the time, I can't even get a response by touching any of the keys.
  • 231 Answers
This is a fixing unit over temperature fault. The device has detcted the fixing unit has gone over 470 degrees F.
You will need to check the Thermisters in the fixing unit, and repair or replace as needed.
Service mode DIP Switch needs to be reset after repairing.
WARNING
• When F34-∗∗, F35-∗∗ or F36-∗∗ (fixing temperature related abnormality) occurs, be sure to repair a defective part before setting the 25 DIPSW 3-1 to 0.
If the 25 DIPSW 3-1 is set to 0 without repairing a defective part, it may cause a fire.
Posted on Apr 26, 2010
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
Konica error code f-51-6
try to reinstall the driver from CD you've when you buy the konica.
or you can download 3DP Chip v11.12 from Mediafire
Open it,and you will found Your driver like Example on the screenshoot,and Click it,you will Redirect to the Driver you've need.
Please don't forget to rate it if this helpfull.
Jan 05, 2012 | Konica Minolta 7145 USB Driver for ISW
I just ask my copier to try to enlarge past 200%, had really little type on the original. It says "call service" code F-35-1. I work from home and need help to clear out this message. Please...
Fuser error, here is the reset procedure.
Set SW2 (sub power switch) OFF and then back ON, after set to "0" the bit 1 in DIP SW3 in 25 mode. (If you switch power back on without releasing the latch, the error will recur.).
Hope helps.
Sep 02, 2011 | Konica Minolta Office Equipment & Supplies
Konica 7145 Legacy Print Driver
konicaminoltaus.com has a complete list of the drivers for download on the site
Oct 09, 2009 | Konica Minolta Office Equipment & Supplies
I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
I HAVE A KONICA 7145 COPIER WITH AN E56-1 ERROR
Main control board unit has been modified to prevent abnormal code.
[How to identify the style]
Current and new styles can be distinguished by the part number printed
on the main control board unit.
(Current) 40LA-9025 => (New) 40LA-9026
Serial Number Cut-in: 40LE02201
TRY
to reseat all the board connections first..
hope that help
Nov 11, 2008 | Office Equipment & Supplies
Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
Oct 29, 2008 | Office Equipment & Supplies
Canon imageRUNNER C3200 Copier Logo
638 people viewed this question
old marine
old marine
