Question about Kicker 06ZX750.1 Car Audio Amplifier
My amp protection light flickers red and green i cant figure out whats wrong
  • 175 Answers
Unplug ure sub and see if it still does it? does it have a good earth and power could be a problem in the amp
Posted on Apr 27, 2010
Green light comes on for a sec the red light comes on,1200 watt sony xplod amp 10'' Orion sub,I think the subs right around 3000 watts. What's wrong?:(
Your Sony Xplod amplifier turns on briefly (green light) then possibly senses a mismatch between the nominal output impedance of the amplifier and impedance of your Orion sub and goes into protect mode (red light) to prevent internal damage.
Jul 19, 2014 | Car Audio & Video
My amp was working good and i didnt use like for two months and know it doesnt work the green light turns on but the red light too of over current and i cant hear nothing i dont know what is it..
if it turns red its a protection light you most likely got the ohms wired wrong on the speakers and the amp is going into protect mode so you dont fry it or the subs
Mar 04, 2011 | Sony XM-2150GSX Car Audio Amplifier
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
I have a KAC 9152d with a red light on. what is the protect light and normal operating light colors? with the red light on the sound doesnt sound as full as it shoudl be. its running 2 12" alpine type R's...
your ampifier is in protect mode, try to dettache the speaker and turn on it.if the green ligh on ,one of your speaker is deffective but still the red light on theres something wrong with your amp.
Mar 03, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Still having amp problems
Hello lilmario,
After eliminating wiring problems and possible shorts, grounds and low impedance in the speakers, most likely the amp is failing internally. A partial failure of either the output MOSFET's or the thermistor. In either case, the repair requires removal and replacement of components on the circuit board. Depending of the age and original cost of the amp, such repairs are sometimes expensive.
I'd recommend having a professional audio shop test the amp and provide an estimate for repair.
Hope this helps.
Sep 21, 2009 | Car Audio & Video
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
May 29, 2009 | Pyramid PB1217X Car Audio Amplifier
Power light turns from green to red protect mode and then there is no sound coming from my speakers
there are 2 reasons for it to be going into protect mode 1 is heat 2 is the load on it. if it is going into protect mode soon after it starts there is a problem with the speaker. if it is after it has been on for a while it is that the amp itself is overheating. hope this answers your question
Apr 27, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Red protection light is on constantly. the light won't turn green
is the remote source have enough amp to triger amp seem like that is you prob and chk you spk wire and rca too-
Mar 24, 2009 | Polk Audio PA250.2 Car Audio Amplifier
Kenwood kac-7202
Nope it's not a high-to-low level converter problem, it's most likely a problem with one of two things. 1) either you've blown the output stage in the amplifier, or 2) you've hooked up your subs wrong and your amp is seeing to low of an impedance. The amp is supposed to be 1ohm stable, but we had the same problem. When the indicator light goes red it means that the amp has gone into protection mode, now you have to figure out why. If something in the amp goes bad or just disconnects from the board it will cause power protection mode. If you fry something on the board because you are running the amp to hard or at the wrong impedance it will go into thermal protection mode, however there's no simple way to figure out which has happened.
Have you tried hooking up some different subs to see if the problem remains? try this. If the problem no longer happens then you know it's your subs, if it does still happen then you'll know it's an internal problem.
Years ago I had a Kenwood KAC-821; long story short, I melted the main power wire right off of the board, everytime I turned the system up the amp would shut down.
Take you amp to an authorized dealer and have them bench test it for you.
Let me know what you find out.
Jul 14, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kicker 06ZX750.1 Car Audio Amplifier Logo
172 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
