Question about Refrigerators
Frig not blowing cold air - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Posted on Apr 27, 2010
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Milk lunch meats freezing
I have to assume you mean on the top shelf of a refrigerator. If so, then you need to look for the air vent(s) that are usually in the rear of frig compartment either on back wall or under the frig compartment ceiling. These vents are pouring very cold air from the freezer and the air needs to get distributed throughout the frig, however the coldness is falling on the milk or meats that are in the way (getting hit with the cold before the air is disipated within the frig).
Three options: if the air vent(s) have a movable or directional cover, then redirect the air so it blows away from the food on the shelves. If there is no movable cover, perhaps adjusting the freezer control (not the frigerator control) to the next colder freezer setting; this will reduce excess cold flow pouring into the frig. 3rd, make a shield of plastic or metal or cardboard to divert the direct cold flow of the air vent from falling on the upper shelves.
Oct 11, 2009 | GE PSC23MGMBB / PSC23MGMCC / PSC23MGMWW...
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
Frig / Freezer not blowing cold air.
your compressor could have chut off.
Jul 27, 2009 | Refrigerators
Estate refrigerator does not cool, but the freezer seems to work fine
open the frig door put youer hand over the vent comeing into the frig there should be cold air blowing with freezer door shut if not then opent the freezer door if you get cold air out of the vent now you have a defrost problem if you still have no cold air the damper door on that vent is not opening it will need to be replaced
Mar 27, 2009 | Estate Refrigerators
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Frig just not Cold
you might have had freon leak out from it sitting unplugged how long were you gone ? plus you need to wait atleast 30 minutes when you unplug your refigerator then plug it back in you cannot keep plugging it on and off it will burn up the compressor / relay overload
Aug 28, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
