Question about Kenmore 24032\24036 Top Load Washer
I have a Kenmore 110-24642300 Top Loader washing machine about 7 or 8 years old. A few weeks ago it started making a very load knocking sound as the motor turns the drum in the spin cycle. It turns the drum just fine, but the noise is very load. Whats wrong, and can I fix it?
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24642300&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
And the following for how to release the console, cabinet and pump, motor, transmission and tub.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=38167c09664cecf006774770a74cf9bc
DON'T BE ALARMED, THE ABOVE ARE REFERENCES AT THIS POINT. YOU CAN FIX IT. (THESE ARE RELATIVELY EASY TO FIX IF YOU TAKE YOUR TIME.)
The first thing to check is how well the tub is attached to the spin tube. Over time, the nut that holds the tub on may have worked loose. The description for how to pull the tub should help.
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
If the tub is firmly attached to the drive tube, the next thing to check is the drive tube itself to make sure that it's not broken. Pull it (following the illustrated instructions and the Service Manual) and check it. Also check the pads / springs for the brake.
NOW FOR THE FUN PART.
If the tub is fine and the drive tube is fine, the problem could be in the gearcase itself. (It's a messy but not difficult job)
There are two plastic cams within the gearcase that lift the agitator shaft out of the way when the washer goes into spin mode. If the cams are worn (they don't have to be broken) they may not lift the shaft high enough (about 1/16") out of the way.
Also see the following for how the transmission works and the whirlpool parts list for the commercial washers (although the consumer models use the same gearcase.)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (15 oz. of oil in the transmission) but very inexpensive.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, check the clutch bands and springs before going further. If they are worn, sears and Whirlpool have replacement spring / band kits. If they are fine, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft.
Remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Posted on Apr 26, 2010
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Codef1
This is a known problem with this model. Call 800-847-9083 and give them the model and serial number to see if your unit is covered by a recall on the control board. I called a few weeks ago and they sent the part and a tech to install it for free on my 3 year old machine.
Apr 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
I have a kenmore 80s series top loader washing machine. The water does not drain all the way on the spin cycle. I have to always run a second spin cycle
I know this sounds goofy but it sounds like the machine has been over loaded a few times and each time the machine is over loaded it makes the springs weaker. That makes it easier to overload with less laundry. Try to put less clothes in and see if that helps. Good luck.
Jun 09, 2009 | Kenmore 24032\24036 Top Load Washer
Load knocking sound
out of balance,or the clothes are not even spread and causes one side to be heavier
Jan 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
781 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
