Question about Toshiba Satellite A15-S127 Notebook
Memeory does not show up
RE: Toshiba Satellite A15-S127:
I removed the original PC2100S-2533-0-A1; 256MB, DDR, 266MHZ, CL2.5; MICRON MT8VDDT3264HDG-265C3; 200 PIN, SODIMM SDRAM, and installed 2 sticks of ELPIDA 512MB DDR PC2700 200-Pin Laptop SODIMM, total 1Gb; (Label on stick reads: 512MB PC2700S-2533-0-A1).
When I run HWiNFO32, a utility program to report hardware, it shows only 512 MB in the Row 1. What is wrong?
The OS is Windows XP.
I saw another posting similar to mine and in it it is advised to check CMOS. Would this aply to my question, also? If so, how to check and revise CMOS. At boot up, I pressed DEL, F5 and F7 keys, but I cannot get to CMOS setting. I only get to the screen to choose Safe Mode, with network, etc.
  • 5 more comments
  • MTAKASHI Mar 24, 2008
    Toshiba's manual states it supports 1 GB. At other web site, I saw PC2700 500MB x 2 pieces for the same model of laptop. So, I assumed these are compatible. Beyond that, I cannot determine. What would you suggest to determine?
    1. The 2 sticks are the same Elpida
    2. The 2 sticks are the same, so they must be the same speed.
    3. I thought pC2700 refers to the speed. Athttp://www.memorydealers.com/51elpalapcd... it is DDR333. Does it mean 333 Mhz?
    You misunderstood. The 2 RAMs I put are both the same Elpida RAMs. If DDR333 means 333mhz, then, both are 333 mhz. The old one, which I replaced and does not exist anymore in teh Laptop was 266 mhz.
  • MTAKASHI Mar 25, 2008
    As I wrote, HWinfo software indicates only 512 mb, not 1GB. How to get to bios? At boot up, I tried Del, F5 and F7, but noe lead me to bios; it simply lead me to boot up option screen, such as safe mode, normal mode, etc.
  • MTAKASHI Mar 26, 2008
    I tried F2 and F10. F10 did not do anything. Pressing F2, the screen simply showed 5 options near the bottom in graphical symbols, the left being several disks, second one disk, etc., and they lead to the same option screen for safe mode, normal, etc....none of them lead me to bios or CMOS. As I noted earlier, the OS is Windows XP.
  • MTAKASHI Mar 31, 2008
    Does it (hitting F2 gets you the Dos screen) apply to Windows XP?
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..have you determined that the replacement memory is in fact compatible with this unit?
    Genius:
  • 3,587 Answers
Sure.
step one...same or different maker(not that important, but nice to know)
step two..speed of the memory(usually in nanoseconds) these need to be within 25% of each other, max. Same is the best
step three..i don't see the processor compatibility speed on the second set you installed. First one is 266MHz..what's the second set rated at?
I know it fits mechanically, but that's only the basics with memory swapping.
Posted on Mar 24, 2008
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Mar 24, 2008
    yeppers..so you have 266 and 333 memory...that might be the cause..can your computer run on either of the combinations(only 266 or only 333)? if that's the case, then you have a basic memory imbalance issue..
  • Patrick Michaels
    Patrick Michaels Mar 25, 2008
    ahh..just working from the information that I read here..so, let's recap..you have two new memory sticks in your laptop, neither of which your bios can see, right? did you go into bios to enquire as to whether those mem sticks are visible at that level?
  • Patrick Michaels
    ok..at boot up, it's F2...to get to bios..or possibly F10, depending on who's bios you have installed..
  • Patrick Michaels
    Patrick Michaels Mar 26, 2008
    that is truly weird..when I hit F2...i get a dos styled screen..this needs to be handled before the logo appears..
Need to find wireless card for Toshiba Satellite A15-S127 laptop
Just get a wireless network adapter and plug it into your USB port...any newer makes will do:)..D-link...so on
Apr 13, 2010 | Toshiba Satellite A15-S127 Notebook
Need LCD screen for Toshiba Satellite A15-S127 15
You can try getting it here: http://lcdscreen.com/ but you should open it up and get the model number and maker of the LCD panel to make sure you are ordering the right one
Mar 18, 2010 | Toshiba 15.0" TFT Laptop LCD Screen
Which jumpers do I short and where do I find them to reset the bios on a Toshiba Satellite A15-S127 (PSA10U-00RESV) PC Notebook?
There are no jumpers on laptops. remove the battery and disconnect the mains charger hold down the on button for about 30 seconds this resets the bios. Replace the battery
Jan 22, 2010 | Toshiba Satellite A15-S127 Notebook
What is another model number that would work for my a15-s127
On Toshiba’s web sit it is listed as 411405 A15-S127. I did not find any other reference. Good Luck
Jul 28, 2009 | Toshiba Satellite A15-S127 Notebook
Toshiba satellite A15 S127 pc notebook -how to set up CMOS: I cannot get into CMOS setup screen at boot up. I tried DEL, F5, F7, F8, etc. The reason I am trying this is as follows; I removed the original...
how to get into CMOS, simplly put F1, OR F2, F10,F12, OR DEL key, but very depend on your laptop itself.
tips, whatever key you need, will show on the boot up screen , like : type Fxxxxx for setup, Fxxxxxxxxx for boot up device order .
for your laptop, may have chance that you laptop too old, some model of ram are not fully compareable.
Jan 14, 2009 | Toshiba Satellite A15-S127 Notebook
Toshiba hard drive craddle
you can go to www.drivesolutions.com
thats where I get all my parts for my toshiba, but they usually have hard drive parts for all major brands.
Sep 08, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127: Memory does not show up
Is the BIOS up to date? if not you can download latest BIOS update from support.toshiba.com
Mar 12, 2008 | Toshiba Satellite A15-S127 Notebook
Sound Problem
You need to install the driver for Sound device that compatible with XP. Since you have indicated the model Satellite A15-S127, I am attaching the link that you can download sound driver for XP.
Here is the link;
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=441097&moid=411405&rpn=PSA10U&BV_SessionID=@@@@1379779449.1203596264@@@@&BV_EngineID=cccfadedgfgdhehcgfkceghdgngdgnn.0&ct=DL&all_docs=false
Please post to inform the outcome.
Good Luck
Feb 21, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127 DVD driver
thats may be because you don't have a dvd .is just a cd drive
Dec 27, 2007 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127 Notebook Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
