Question about Garden
I have a Husqvarna 55 and it will cut but not great. The chain will stop and the engine will bog even on full throttle. Is it the clutch?
  • David Oct 29, 2012
    My husqvana 55 is like he said. Blogged down, cutting it. WHAT IS WRONG?
  • 57 Answers
Is your chain sharp? Sometimes you hit stuff in wood without realizing it and it dulls your chain, dirt, nails, trash, it's all bad for the chain. If you aren't getting enough oil on your chain while cutting it will also shorten the life of your chain dramatically.
Posted on Apr 26, 2010
  • David Nov 02, 2012
    I do not think so and yes I always sharpen. Its been 18 or 19 years with my chain saw. And it will last all my life. Add a Comment
    Add a CommentI do not think so and yes I always sharpen. Its been 18 or 19 years with my chain saw. And it will last all my life. Add a Comment
Husqvarna 55 chainsaw has a problem running on idle
start by checking all ur fuel lines for holes then proceed to clean or rebuild ur carb the ethonal in fuel is cloging small engine carb jets and making needles stick so then adjust ur carb back to factory settings try with new air filter as well and run 89octane or higher in your two stroke motors u will c a great differance in performance
Dec 13, 2012 | Husqvarna Chain Saw Models 51, 55
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
My husqvarna 178 keeps cutting out on full throttle have tried to adjust the L and H settings with no success any ideas?
As far as i remember Husqvarna never produced a model 178, however if adjusting the mixture screws does not help there is either a fuel blockage in the fuel filter in the tank ( replace filter ), or the fuel screen in the carb ( strip clean and service carb ), check the fuel hose hose for splits or cracks, asthis will greatly effect the running
Mar 30, 2011 | Husqvarna Chain Saw Models 51, 55
How many turns out is the High and Low screws suppose to be adjusted. Also how many turns out is the larger idle screw suppose to be.
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting which should allow the engine to start and run. Before adjusting anything, check the fuel filter, air filter and muffler for plugging. Start the engine and allow to warm up. Pull the throttle full on and adjust H needle CW until the engine begins to speed up, but still 4-stroking. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to idle. Hope this helps!
Jul 11, 2010 | Husqvarna Chain Saw Handle Models 50 51...
Chain saw carburator settings for husqvarna 61
Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow the engine to warm up, then pull the throttle full on. Turn the H jet screw CW until the engine starts to speed up, but still 4-strokes. Proper adjustment occurs when the engine is 4-stroking, but immediately 2-strokes when cutting. This gives best power and lowest heat. Release the throttle and adjust L jet CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
While cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Jan 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
The chain slows down or stops when cutting. The engine runs fine and doesn not slow down. I checked the oil, cleared the oil vents to the chain, the brake is fine and is not causing the problem. The...
THE SAW IS RUNNING FINE . WHEN THE CHAIN STOPS AND THE ENGINE IS STILL RUNNING AT HI THROTTLE THE CLUTCH MAY BE WORN AND SLIPPING. PULL THE CHAIN AND BAR AND SEE IF THE CLUTCH HOUSING IS BLUEISH IN COLOR IF SO I WOULD REPLACE THE CLUTCH
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a husqvarna 55. I put in a new carb, coil,
Preset both needles about 1-1/2 to 2 turns CCW from CW stop. Set H needle first after warm-up. At high speed, engine should 4-stroke with no load, but smooth out with light load(cutting wood). Set idle speed so that it will keep running, then adjust L needle so that engine tries to follow the throttle, but idles fairly smoothly. Readjust idle speed so that the clutch is not trying to drive the chain.
Aug 02, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Saw will not cut , chain stops turning when chain touches wood
If your saw has a removable sprocket, Check the drive sprocket on the clutch drum. Either the the spline is worn or the drive link on the chain is not properly seated in the sprocket well.
Apr 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Runs great for 30 sec. to 1 min. then dies slowly
Is it your chain saw Husqvarna 40?
Try carb adjustments H-3/4 turn ,L-2 turns and T a little higher
I presume that compression and ignition sistem is adequate for the engine to run.Good luck
mihai
Apr 04, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
