Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Filter pops out in middle of cylcle
During brewing sometimes the grounds filter pops out letting the coffee go all over the counter instead of in pot. Doesn't always happen=usually only when we are not watching!!! Pain in the u know what. We also have the problem of not always completing the whole cycle-only ending up with half a pot for whatever reason, and sometimes just going all over the counter. Think we might think twice before spending that kind of money again.
  • 4 more comments
  • needmyjoe May 28, 2008
    Mine is about two years old and it started last week to pour all over the counter as well. Not only when we aren't looking either, everytime!! I've tried cleaning everything out in case there was a clog, but it's still happening. I'm ready to throw it out but it was not a cheap coffeemaker...any suggestions??!!
    desperate for my morning coffee!!
  • donanddody Jun 04, 2008
    Occasionally pops out and runs all over the place..now set half way over the sink so it goes down the drain....Like the other lady said..always when I'm Not looking...Now it doesn't work at all ..grinder works but does not drip..husband thinks perhaps heating element is burned out. Had it for a year. It is so beautiful, can't bring myself to throw it away..Any suggestions?
  • kboklund Aug 15, 2008
    My filter basket frequently pops out while in the grinding cycle, throwing grounds all over the place. What is causing this? The basket seems to be ok in the brew cycle, just happening during the grinding.
  • janemack Aug 16, 2008
    We have the same problem. My husband determined that you can only use certian coffee like WaWa or Dungan Donuts coffee used in the machine. I spent a fortune for the coffee maker and it only brews correctly every so ofter.
  • Anonymous Nov 11, 2008
    Mine does the same thing, filter pops out when I have it set for auto in the morning. I go down to get my coffee and there is coffee and grounds EVERYWHERE. I think the latch that holds the door closed had a spring that is loose and it pops open when the grinder vibrates the machine?? Think I am getting a new coffee maker, maybe Krups?
  • Anonymous Nov 17, 2008
    A bad production design that they don't seem to care about fixing. The only solution is to buy another brand.
I periodically take a wet Q-Tip and clean around and inside the "slides" for the brewing basket door, so that it slides in and out easily. (I was amazed what the Q-Tips look like after you do this.)
I think the problem lies in the fact the basket does not go fully back and engage the latch due to the gunk that builds up on the slide. You think you fully closed the door when you feel the resistance of the gunk, but you are only marginally latched - the vibration of the motor pops the door free and VIOLA! coffee-ala'-counter!
I think the gunk comes from very fine ground coffee dust, mixed with water that condenses from the steam that envelops the unit during brewing.
I also clean every surface in the brewing basket area with a wet paper towel,
Posted on Nov 08, 2008
    Problem Solver:
  • 7 Answers
I used to have the same problem often... now I keep one of those cans of compressed air usually used to dust off electronics and insert the straw into the slides on each side and blast out the coffee grounds and debris. This seems to free up the slides and the latch can catch better.
Posted on Feb 18, 2009
We have the same issue. We returned our first unit when this happened but the same thing occurred with the new one. It's a cheap little plastic piece that acts as the latch that holds the filter in place. I suspect that this piece gets worn and then can't hold back the spring any longer.
The work around I've used for this problem is to wrap a piece of velcro tape around the filter box. You can get the stuff at any hardware store. I made a loop that fits around the top of the entire unit at the top of the filter basket. It has some slight elasticity so when I close the basket and pull the velcro down it holds everything together tightly, even when the latch lets go.
Since I've started doing this I've had no problems. I chose thin black velcro bands to do this. Because of the coloring it looks like it's part of the unit unless you look closely.
Not a true solution, but a decent work around.
Posted on Sep 29, 2008
SOURCE:
How do you brew a pot of coffee? Someone gave us a machine for our wedding and it just sits on the kitchen counter doing nothing.
I'm assuming you've got a coffee filter pot as this is the most common kind (especially as wedding gifts).
1. Boil the water.
2. Put the filter (should come with the pot) into the filter holder.
3. Add 2 level tbsp. of ground coffee per 6 oz of water.
4. Pour some of the hot water over the coffee grounds, giving them a few seconds to swell.
5. Now add the rest of the hot water and allow the coffee to slowly drip through the filter.
6. Remove the filter with the coffee grounds in just before the final drops of water go through.
7. Now sit down and enjoy!
Feb 25, 2013 | Home
Coffee in Cuisinart grind and brew ends up all over counter
once and a while the filter door will come ajar and make the coffee leak all over. (allways try to jigle it open after closing, because fine grounds will make the door not close right) Also if the carafe is not in all the way you'll geta mess too!
Jun 29, 2009 | Cuisinart Thermal DGB-600 Grinder
Leaks while filling
Mine just leaked and it turned out to be one of the rubber tubes from the reservoir to the heating element under the pot came off. I removed the 4+2 screws of the base plate, reinstalled the tube & since there are no clamps holding on the tubing, I used thin stainless wire double wrapped and snugged to ensure the tubing stays on this time. Note, there is wiring in the area. Make sure you do not short out any of the electronics with the wire if you chose to use it.
Sep 26, 2008 | Mr. Coffee FTX49 12-Cup Coffee Maker
Filter basket opening during brewing
Push the permanent filter's basket handle all the way down and then reclose the filter basket drawer lid. There is a pretty flimsy piece of plastic holding it in, though - may require replacement.
Sep 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Fetco CBS-31Aap over brewing
It's possible that your airpots are too small. We have the same machine and 3.0 litre airpots and it's perfect. But I can't find the right filters for it! I'm currently using a bunn filter and MOST of the time I end up with a lot of grounds in my coffee.
Jun 18, 2008 | Fetco International CBS-31AAP
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Over flow
I think you have to be careful in how much water you put in. I had the same problem the first few times I used it. I started to only fill until the water just met the 10 cup mark, not over it. I have not had the problem since.
Dec 30, 2007 | Cuisinart Grind and Brew 10 Cup Coffee...
Filter basket pops open after grinding GROUNDS AND WATER EVERYWHERE!!!!
I had that problem a few times. When the door is open and the basket is removed I pushed in and held the release button while I cleaned that little hook area that holds the pop out tray in place. I just used a paper towel and nicely warm water. Works fine afterwords. I try to clean this at least every week.
Jan 27, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
143 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
