Question about Kenmore 64992 Electric Dryer
Dryer quits when you let go of the starter button
Every thing seems to work if you hold the button in #110.64994300
  • 784 Answers
The relay needs to be replaced.
Posted on Apr 28, 2010
MEDC400VWO Electric Dryer won't run
Have you got power going into the machine?
NUMBER 7 is the fuse you must remove the wires to do the check
My page of this type dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 04, 2012 | Maytag Dryers
Bike wont start just quit working one day it doesnt try to turn over battery is good and holding voltage, have checked all fuses, starter relay, kill switch, ran up and down that bike with a volt meter...
Push the starter button if your hear the solenoid clicking the starter button is good. If there is no click from the solenoid you may need to clean or replace the starter button.Follow the positive battery cable to the starter solenoid. Jump across the two cable terminals, this should activate the starter.If the starter works now you have burnt contacts inside the solenoid. replace the solenoid. If the starter does not turn over, try again tapping on the starter with a plastic hammer if the starter works now you need starter brushes. If the starter will not turn over with direct power (bench test) and the brushes are good the armature is probably shorted. You will have to replace the starter as an assembly parts are not available to rebuild the starter.
May 10, 2011 | 1986 Yamaha XJ 700 X Maxim
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
Start button does not kick the dryer on
Looks like your drive motor is locked up. It has an internal overload switch which cuts power off when motor gets too hot...Replacement of the motor on a used dryer is probably not the best choice as it can be quite pricey..
Jul 09, 2017 | Maytag Neptune MDE5500AY Electric Dryer
93 Suzuki 800 Intruder just quit starting
If it was the relay, you probably wouldn't hear it clicking. you may be able to hold the starter button, and tap on the starter lightly to see if it works.
Aug 11, 2009 | 1999 Suzuki VS 800 Intruder
Dryer shuts off after releasing "push to start"
this problem sounds like it can only be 1 of 2 problems. the start button or the motor is not going into run winding. i found over the years that the blue wire i believe is burnt at the motor. this can be repaired quite easily .cut the wire and strip it putting a new connector on. if you need to you can buy an assortment at a hardware store. if every thing is good check the start button for burnt wire if ok then you most likely have a bad motor. i'm pretty sure though that a wire is burnt off at the motor
Jan 30, 2009 | Kenmore 67082 Electric Dryer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 64992 Electric Dryer Logo
79 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
