Question about Dolphin Maytronics Advantage
Where can I find parts for my power supply dl 9995655 ?
    President:
  • Dolphin Master
  • 1,378 Answers
Use the dolphin button along the bottom of our site www.arrowpools.net and put what parts you need in the comments section. We'll quote the items you request. You may also want to include your symptoms so we can confirm the parts you are requestion will fix what ails your unit.
Posted on Apr 26, 2010
No power. Checked outlet, which is fine. Plug into the printer is in all the way. It was working this morning and now nothing.
It sounds like the fuse on your power supply is burned or the power supply board itself needs replacement.
Jan 13, 2011 | Konica Minolta Magicolor 2530 DL Laser...
Beeps 15 times and displays a "dl" then "F" on the screen. It has power, but will not start. Nothing has changed to power or water supply.
F is a failure, dl is door lock,
Something has broken or malfunctioned with the door lock mechanism. Make sure nothing is causing the door not to close properly. If all is well you most likely will need a new latch mechanism
Apr 24, 2010 | Kenmore Elite HE4 Electric Dryer
Hello there, I got Asus PC-DL Deluxe UAYZ motherboard and would like to connect to ATX 300W 20 pin power supply. Do you think it works, or should i wait till i find 24pin power supply. thanks for your...
This motherboard is designed to be used as a workstation or server. This mother board will need a specific power supply designed for this board as it can use 2 Xeon CPUs. Setting this board with the incorrect power supply will cause the system to not power up or at worse result in damage to the CPU, motherboard, memory, video and other devices including possibly the power supply. I suggest obtaining the proper power supply for this motherboard
The manual for this board states that the motherboard requires a 24 pin ATX power supply that also has an 8 pin 12 volt connector. The manual from ASUS recommends no less then a 300 Watt power supply. I would professionally recommend 500 watts or more if the system will use 2 CPUs and many hard drives in a RAID array.
A suitable power supply can be found here at Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16817163111
The manual is here at ASUS's support site at http://support.asus.com/
Feb 24, 2010 | ASUS PC-DL Deluxe (90-MSV290-G0UAY)...
Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Jun 03, 2009 | Sharp LC-26D43U Television
Flashing OPC/DL light
Here's what I did to fix issues with my 37D5U - do at your own risk:
***Follow the instructions below to fix the same issue in your LC-37D5U tv***
Do this test first to confirm the failure:
(1) Connect the cable line to the tv.
(2) With the tv unplugged, hold down the Input and Volume-Down buttons simultaneously, then plug in the tv.
Expected result:
(a) You should hear the tv come on in the service mode; the OPC/DL and power lights on the front of the tv should turn green and blue, respectively.
(b) The broadcast sound should come through the speakers, but you will probably still have no picture or back light.
If your test yields the expected results, proceed to the fix.
Fix
Parts Needed
(1) Part type: Fuse
Location on circuit board: F705
Official Part No: QFS-A1154SNEZ
Replacement Part No: BK/PCB-1-R (Mfg: Cooper Bussmann - about $2) or the original QFS-A1154SNEZ (Distributor: Sears Parts Direct - about $14)
(2) Part type: Mosfet (4 of them)
Location on circuit board: Q723, Q721, Q719, Q717
Official Part No: k3469
Replacement Part No: FQPF13N50C or FQPF13N50CF (Mfg: Fairchild Semiconductor - about $2 each)
Fuse F705 is part of the circuit on the power supply that powers the inverter circuit, and the inverter switches on the back light for the tv. The mosfet at location Q723 was suspect when I tested it, so I went ahead and replaced it and the other three mosfets "chained" to it as preventative maintenance. Parts can be bought from digikey.com - digikey is usually a same-day shipper with the best prices, so I use them. USPS Priority shipping is the best bang for your buck.
Tools Needed
Philips screwdriver
Soldering iron
Desoldering braid or some other solder remover
Light bulb socket that has two wires running from it and a clear 100-watt light bulb - Home Depot sells the sockets. Alternatively, you can use a 2K ohm/10W resistor
Multimeter - not necessary, but helpful
Procedure
(1) **Important: Make sure the tv is unplugged**
(2) Remove the back cover and stand - there are a bunch of screws holding the back cover on. You can either mark the screw locations and bag the screws or do what I did: Unscrew the screws, leaving them in their holes, then slowly lift the back cover off and carefully set it down with the screws intact.
(3) Set the tv on a flat surface with LCD panel facedown and remove the AC power cable.
(4) The board you want to work on is the power supply board (see pic below), which is the board where the AC power cable connects. Carefully detach the connectors that connect to the other boards in the tv from the power supply, then remove the screws that hold the power supply to the back of the tv and lift it off the tv by holding it by its edges.
(5) Locate the four large 450V capacitors at locations C734, C709, C710, and C852 without touching them (they look like soda cans). Flip over the power supply board. Touch each wire of the socketed light bulb or resistor for about 3 seconds to the negative and positive leads of each large capacitor, respectively; polarity is irrelevant. This discharges the high voltage from the capacitors so you don't get shocked while working on the power supply. The voltage usually slowly dissipates on its own, but it's better to be safe than sorry when you're talking about a potentially lethal 450V. Check the voltage with your multimeter in the appropriate DC mode to verify that the capacitor voltage has been drained; if you don't have a multimeter, just continue on.
(6) At this point, you can verify that the fuse at location F705 (looks like a small black box) has indeed failed by holding the multimeter's red and black probes on the fuse's leads with the multimeter in continuity mode. If you have no continuity, the fuse has internally failed; proceed to the next step.
(7) Desolder the fuse from location F705 and desolder the mosfets from locations Q723, Q721, Q719, and Q717 then replace with new components.
(8) Put the power supply board back in the tv, using just a couple screws to hold it in for now. Reattach the connectors to the power supply.
(9) Attach the broadcast cable line.
(10) Reconnect the AC power cable to the power supply (don't plug it into the wall socket). Hold down "Input" and "Volume-Down" simultaneously, then plug in the tv. The tv picture and sound should come on.
(11) With a small screwdriver or other probing device, depress the Reset button, not the System Reset button; it's the last recessed button below the cable jack on the back of the tv. The tv will reset, then you should get sound and a picture from channel 2.
(12) Reinstall the remaining power supply screws, back cover, and stand.
May 26, 2009 | Sharp Televison & Video
1984 DL in tank fuel pump.
Check the fuses, I think power to the tank pump is supplied via a fuse. The pump will have power all the time!
Feb 25, 2009 | 1984 Volvo 240 Series
Dolphin Maytronics  Advantage Logo
304 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
