Question about HP Pavilion 6640C PC Desktop
How do I remove Hard Drivew from 6640C - HP Pavilion 6640C PC Desktop
  • HP Master
  • 5,660 Answers
1) Computer off, and unplugged from power.
2) Work on a table, open the computer case.
TOUCH the metal frame of the open computer case to relieve your body of Static.
[Your body carries Static electricity. Static will fry out (Short Circuit) the delicate hardware components inside a computer.
Computer unplugged from power, you are safe. TOUCH the metal frame, your computer is safe.
Should you walk away in the middle of working on your computer, when you return Touch the metal frame again ]
To open the computer case three screws have to be removed from the backside of the computer case.
The computer case is a shell, that resembles an upside down U-shaped hood.
Looking at the back of the computer you can see where the U-shaped hood wraps around, and forms a 1 inch lip.
There is a screw approximately two inches up on the Right, and Left side, and a screw at the Top, in this lip. Remove them.
Slide the U-shaped hood back about 1 inch, lift the hood up, and off.
{Note* The metal frame of the computer case has a Notch at the front/top on both sides.
The U-shaped hood has a metal Tab that protrudes inward on both sides.
The metal tab lines up with the notch, so that the tab can slide up through the notch.
This is why the U-shaped metal hood is pulled back towards the rear of the computer ONLY 1 inch, THEN lifted straight up.
You are now looking at the metal frame of the open computer case, and the internals of the computer.
This document from HP Support shows, and details the above,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph05156&lc=en&dlc=en&cc=us&product=59928&lang=en
The harddrive is located at the inside front of the computer.
The harddrive is an IDE harddrive made by Seagate.
Note* IDE is also referred to as EIDE, ATA, and PATA.
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
Remove the 4-pin Peripheral power cable connector from the rear of the harddrive.
This one,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Remove the 40-pin flat ribbon cable connector from the harddrive. (Interface cable, or also known as a Data cable)
You'll note there is a metal bracket that surrounds the harddrive.
There is a screw at the top of the bracket, and one at the bottom of the bracket.
These two screws hold the bracket in place, close to the front of the computers metal case framework.
Remove them.
Remove the harddrive.
(The Seagate model number ST320423A is a 20GB IDE harddrive.
The ST315323A is 15GB IDE harddrive.
The ST310212A is a 10.2GB IDE harddrive )
Posted on Apr 26, 2010
  • 119 Answers
Here is your link to assist you.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=59928&
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
How to create samsung recovery on my disk drivew from online
Most of the time you get a recovery Disk with the computer, if you do not have one you can recover the computer from built in recovery partition, if you do not have that option contact samsung support to order one
http://www.samsung.com/us/support/
Feb 07, 2014 | Computers & Internet
Owners manual 1015008rul
Since you don't give much info to work with...I'll guess you don't have your owner's manual. Contact HP for help.
Nov 16, 2013 | HP Pavilion 6640C PC Desktop
1994 ford ranger runs fine until i go to town then just shuts down but will crank over and fuel is getting to it
check ignition pick up its in the distributor. its responsible for spark in the plugs
Dec 04, 2012 | 1988 Ford Ranger
REAR FAN FAILURE DELL OPTIPLEX 755
This is the rear fan
Replacing a Hard Drive Fan
  1. Follow the procedures in Before You Begin.
  2. Remove the computer cover (see Removing the Computer Cover).
  3. Remove the hard drive (see Removing a Hard Drive).
  4. Turn the hard drive upside down, so that the hard drive fan is visible in the bottom of the drive bracket.
  5. To remove the hard drive fan:
    1. Lift the release tab on the back panel of the fan.
    1. Rotate the fan in the opposite direction from that indicated by the arrow on the back panel of the fan.
    2. Lift to remove the fan and its back panel from the hard drive bracket.
klamma16.jpgReplacing a Hard Drive Fan
  1. Follow the instructions in Before You Begin.
  2. Remove the hard drive (see Hard Drive).
  3. Remove the hard drive fan:
    1. Remove the screw that secures the fan release tab to the hard drive bracket.
    1. Press down on the fan release tab, and then slide the fan towards the front of the computer so that its side tabs are free of the corresponding slots in the hard drive bracket.
    2. Lift to remove the fan from the hard drive bracket.
    3. Unplug the fan.
May 30, 2011 | Dell Optiplex 755 Ultra Small Form Factor...
Owners manual formy desktop pc it is an HP Pavilion 6640c. I need to locate the connection on the motherboard for the power switch located on the front of my PC as I have replaced it and did not label...
May I respectfully suggest you re-list your problem asking for a photo of the mother board around the power cutton?
I am not aware of a diagramme for the pc and there must be someone out there that can help you out.
Jan 07, 2011 | Computers & Internet
How do i remove a cd-rw from pavilion 6640c?
i this is a desktop ..just open the computer by removing the screws from the back ...and after that the sides will slide out ....the actual cd unit will have screws on both sides that needs to be removed...and will slide in forward ..the cable need to be unplugged also ..the ide controller is the the longer plug with he wide ribbon ..and the other one is the power supply ..thats all...same thing to put another one in..
Mar 20, 2010 | HP Pavilion 6640C PC Desktop
I have a Saab 93 TID (2005 Vector) KEYFOB PROBLEM!
I suspect you have a problem in the security system receiver module, which in most cars must be programmed by the dealer.
May 12, 2017 | 2004 Saab 9-3
Sony Q58A will play DVD but not audio cd or data cd. Help!!!!!!!
Are you sure that you have the file type associated in your Windows operating system to a Music player like Windows Media or iTunes? This may be the most common reason that music CDs won't play.
Sep 16, 2009 | Sony DWQ 58A 8x8x4 Slim DVD RW w/ NTI DVD...
Bad image checksum and not reading a hard drive
Please give more info about this.
Try to reformat your Hard Drive and install it againg freshly. This might do the work.
Mar 03, 2008 | Microsoft Windows XP Professional for PC
HP Pavilion 6640C PC Desktop Logo
196 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
