Question about Siemens SX66
Siemens sx66 wont work
I tried to upgrade the software to windows mobile 6.0, but when i click on the update, the screen only said " Serial v2. 07". I want to reset it but it the same thing comes up. can anyone help me
    Problem Solver:
Download mitty 1.42 file from this website.
www.tompda.com/bbs/display.asp?forumID=2052114&luntan=27
Posted on May 25, 2008
Freezed SX66 at the initiation Windows page
This could be an internal problem on the device, cause of instant shock cause of dropping it. You better try to remove the battery for a while to reset and restore the system.
If the above recommendation did not solve the issue, try to remove the memory card, if still not working try to update the firmware of your unit.
Let me know here again for the update.
micro
Jul 19, 2009 | Siemens SX66
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Phone keeps rebooting
is the button near the reset hole? possibly the button is somehow pressing the reset switch, possibly stuck somehow. Other than that try a hard reset, instructions below.
Soft Reset
Put your stylus in the hole in the lower left corner where it says “Reset” Soft Reset will reboot your device just like when you reboot your PC. No data will be lost, under normal circumstances that is.
Hard Reset
Hold down the Power button (Top Right corner) and at the same time put your Stylus pen in the hole where it says “Reset” (Lower Left corner).
Hard Reset will delete all data you have put on the device, Programs, Settings, Mail, SMS, MMS, etc., so be careful and make a backup before doing this.
After a hard reset, you will have a complete clean new install of Windows Mobile on your device.
Things that are not deleted
  • Data on \Storage Card
  • Data in \Storage folder
Oct 15, 2008 | Siemens SX66
Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
Jun 23, 2008 | Siemens SX66
Can't hard reset
I enter a password and forgot the same.I tried to hard reset the pda as given in the manual by pressing the power button and the soft reset button for 6 secs.But the instrument goes only to the password window.I tried many times the hard setting but no success. Instuct me how to solve this
May 23, 2008 | Siemens SX66
Screen says USB or Serial on top and v2. 07 at the bottom
Open the Back Cover.. remove the Battery, Simcard, Memory Card and then leave it open for 1 minute.
Put the battery back, start your device then if you get the same message you need to update the firmware...
In the worst scenarios, your Siemens SX66 has a corrupt ROM and need to be fixed as in "Hardware"... which can be done by a Siemes expert.
Good Luck
Can't reset
Do a hard reset take the battery out leave it for sometimes may be 15 20 minutes and then put the battery in and turn on it should work fine
Screen
I would recommend using Pocket PC 2003 version normally. WM 5 or 6 may have significant issues with phone compatibility. If you can go back to 2003 and the phone still doesn't work there may be a hardware issue, then you need to replace or repair. Replace is usually the better option. Search ebay.com if that is what you need.
Below, instrutctions on getting ROM for PPC 2003:
Try www.xda-developers.com and ebay for ROM upgrades. There are many people who unlock these kinds of devices. I don't believe you can upgrade it to WM 5.0 or beyond, but that may be possible. Search for WM versions that include "unlocked" versions. The best bet is a newer version of PPC 2003.
The process is relatively simple. Once you have your ROM on CD or via download, You run it with your device hooked up to your PC via cable/cradle and connected via ActiveSync (3.7 or later). The warning is an improper ROM load could make your device unusable. It is a risk you have to take if you want it to make calls. Toss up: no phone Pocket PC, pocket PC phone, or shiny brick. If the XDA site has recommendations on a ROM source, they are not likely to steer you wrong. They will state emphatically, that you do not want any interruptions in the ROM upgrade process. If you have a power outage or something shuts off for any reason, you will have the shiny brick and be looking for a new device.
Help me
Check hard reset. Turn off your pda and hold on the turn on button as same time you make you normal reset.
Lucky
Nov 26, 2007 | Siemens SX66
VERY WEEK NETWORK IMEAN SIGNAL VERY LOW
Network signal strength is not based on your phone. It is based on the network. Poor sigal is their problem, Call them. If this rates as helpful, please post as such.TY
Sep 11, 2007 | Siemens SX66
Siemens SX66 Logo
211 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
