Question about Refrigerators
LG Washer Our barely three-year old LG washer is great, except that i noticed rust has been forming around the detergent dispenser. When I asked LG customer service online and by phone about this, they said it's "cosmetic" and could do nothing. Therefore, the unit can simply continue to totally rust away at this rate as it, of course, is getting worse. Our almost 20-year old moderately-priced Kenmore never rusted. Considering the cost of the unit and the rest of the features being good, this is very sad. Any advice?
  • 26 Answers
Unfortunatly this is real world. If you want to preserve this products look and further rusting. Sand the affected area, prime and paint. LG has touch up paint available thru your local part distributor. G Luck
Posted on Mar 31, 2008
    New Friend:
So, we have the wipe the rubber seal after every wash, and now I see we should wipe the dispenser area down after every wash too.
Yeah, really saves time...
Posted on Jul 25, 2012
  • bamboodragon
    bamboodragon Jul 25, 2012
    New Friend:
This is a crock. Cosmetic maybe but caused by a leaky dispenser.
And LG still won't take responsibility.
You work for LG, Joe?
Posted on Jun 07, 2010
  • juxtaposejac Sep 26, 2010
    We had to replace the dispenser on our red front loading washer because a contractor finishing the laundry room damaged it. They are available for $67 if you want to just replace it. I agree that LG's customer service is less than acceptable, I like the products but hate dealing with the company.
SOURCE:
OMy front load LG washer is gushing water from the detergent dispenser!! Repair suggestions???
Some washers are designed to flush the detergent dispenser to eliminate residue after each wash cycle.
Feb 02, 2015 | LG 3.9 cu. ft. Front-Load Washer, Metallic...
I have LG washer and dryer and its making loud noise, specially when its spinning. Do you have any suggestion. this washer is only 4 yrs old
The most common reason for a loud noise on spin cycle is that water has got into the bearings and forms rust. The ball bearings are no longer smooth. Hence the noise!..Probably the most common F/L washer reason for demise. If the inner bowl is loose and 'floppy', it would be for the same reason.....Overuse of detergent will do it every time!.....Sorry.......Nomess
May 16, 2010 | LG WM3431 Front Load Washer / Dryer
Soap drawer is filled with water
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
May 09, 2010 | LG WM-2277HW Front Load Washer
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Nov 11, 2009 | LG WM2277H Front Load Washer
I've had an Amana Washer model ALW880QAW for about 6 yrs. Recently I've noticed old clumps of old detergent and fabric softener in the wash. I've already cleaned the fabric softener dispenser but the...
I couldn't wait for a rely on my posted question on March 6,2009. I was able to ask around to figure out how to clean this up. This Amana washer model has an agitator that is just clipped on. I just got my fingers underneath the agitator and pulled it off. After getting the agitator off, I was able to clean all of the old built up detergent and fabric softner with some old fashion scrubbing. Then I used some CLR to get what ever I missed. I pushed the agitator back until it clicked back into place and ran one washing cylce to clean things up.....Works great....No more old clumpy stuff showing up in the wash....
Mar 06, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Oct 11, 2008 | LG WM-2277HW Front Load Washer
LG washer leaking problem
You may be using too much detergent.  Use only 2 tablespoons of detergent in your wash.  Using too much will oversud the machine causing the suds to go out the back vent and on to the floor giving the sense of a leak.
On the dispenser, make sure that the containers are clean and free of any debris.
Jul 16, 2008 | LG WM1814CW Front Load Washer
Refrigerators Logo
1,070 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
