Question about Hotpoint RB787 Electric Kitchen Range
I have a RB797W,oven not heating
I have a RB797W,all items working fine except the oven wont heat ,is it an element?
  • Hotpoint Master
  • 43,501 Answers
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 27, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Hi, It looks as if my heating element on my AKZ446/IX oven has gone, as the fan, oven and grill work fine but no heat come out from the oven. I've seen on the online videos how to change the heating...
NEmmake sure you removed the correct item first
replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
Jan 26, 2011 | Whirlpool AKZ159IX Oven
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Frigidaire model MGF331BFWA...Oven isn't lighting(heating)up
Stove wont heat up. Stove top elements are working fine. do you think it is the heating coil/element in the oven?
Mar 01, 2009 | Ovens
Lower oven does not work. Ind. light comes on but no heat
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven wont heat
check the outlet for 220 and the power cord
May 25, 2008 | Ovens
Oven bottom wont heat
can you seee the lower bake element? usualy when bad it will be apparent with a visual inspection of the element.if there is damage to the element order a replacement . 2 screws and 2 wires . no problemTURN OFF POWER ITS A LIVE ELEMENT AT ALL TIMES!!!!!!!
Mar 16, 2008 | Frigidaire FEF336BC Electric Kitchen Range
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Hotpoint RB787 Electric Kitchen Range Logo
118 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
