Question about Sunbeam 805810 HeatSense Heating Pad Heater
Malfunction heating pad
I have a sunbeam heating pad model number cat92 with control model pc204. Everytime I turn on the controler it will work for about 2 seconds and then it will go to F2 and stay that way. I don't know what that means and how do I fix it? Thanks
Mike
  • 11 more comments
  • Anonymous May 19, 2008
    We've got the same problem. Any help?
  • parks1608 Jun 01, 2008
    same here...sometimes itll stay on for awhile then it says F2. sometimes i can get it to shut off and other times i have to unplug it.
  • Anonymous Jul 07, 2008
    Mine just started having this same problem - what's up with that?
  • Anonymous Sep 07, 2008
    my heating pad either reads F1 or F2 then shuts off. have to unplug it to restart. sometimes it happens withins minutes. cant find a resolution anywhere.
  • Anonymous Oct 08, 2008
    Mine is a CAT 93 but same error. Stays on for a short period and then gives the error and quits heating.
  • Anonymous Dec 03, 2008
    same
  • Anonymous Dec 13, 2008
    same here ~ F1 error consistently on my cat92 sunbeam heating pad
  • armedgirl Jan 22, 2009
    same problem just happened with my cat93, which i think is the #902 model. i've had it one year and used it about 6 times.
  • nanishurting Feb 13, 2009
    sunbeam 902 worked fine, until last couple of weeks, f-1 or f-2 almost within a minuite of replugging it in. What's up........need this thing
  • lbuckner Feb 24, 2009
    I have the same problem with my Sumbeam model 902 heating pad it gets an F2 or F1 code and quits heating/
  • Kiley Drury Dec 31, 2012
    same problem!! brand new purchased from CVS F2 stopped working after it melted the plastic to by back & burned me badly
  • randy fertel
    randy fertel Oct 14, 2013
    did anyone find a fix?
  • randy fertel
    Anyone find a fix for F2?
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Posted on Dec 13, 2009
  • 2 more comments
  • hiipbone Mar 07, 2011
    That didn't work for me. I still get F2 and no heat. Heating pad is not much good without heat. Agreed?
  • Carrie Nolan Nov 05, 2011
    OMG, that totally worked ! I've been going nuts trying to figure it out..thank you !
  • Spoiled4sure Dec 07, 2011
    I was having the same problem and this was the fix!! Wish i had known that before because i threw my last one away because of the error code! Thank you!!
  • Suzanne Wood
    Suzanne Wood Dec 16, 2013
    Thank you ,that fixed mine too!
Found plug going into Sunbeam PC204 Cat 92 pulled a bit loose. Pushing plug back in eliminated F1 error message and pad not heats normally. Check the simplest thing first.
Posted on Oct 25, 2010
  • howard975 Feb 03, 2011
    Have 2 of them - one working, the other failed with F2 error...
    these gadets have a micro controller in them (two it seems) one to control the heater, one for the LCD display.
    Though my background's in electronics, I don't have the test equipment needed to figure out what's happening. This is what I determined, however: plugging the working controller into the pad of the broken one, the pad heats (as I thought it would). Unplugging it while on triggers the F2 error. Turning it off and back on (not plugged into the pad) causes an F1 error.
    The bad controller is always stuck at F2 - screen flashes for a second (probably the self test mode of the display), then goes to F2 ** no matter what combination ** of pads or plugging/unplugging I've tried. Since these are so simple, powering off and on is what resets the controller and electronics. Since the bad controller doesn't work on either pad, that means the controller is bad.
    I openned the unit up turned off. (Don't do this if you are the least bit uncomfortable working with 110 Volts AC.) There's a small wire fuse inside - it was not blown. However, there was a fair amount of loose solder chips floating around on the circuit board - indicative of both sloppy workmanship and lousy quality control. I spotted the shiny globs of solder *immediately*. ... so one of these little guys probably shorted one of the microcontroller leads ... and it's brain got heated instead of the pad. Toast-ola
    Made in China by Sunbeam ... I now fully agree with solution #1
    New Friend:
Controller Model SWT200C. Model: 2013-511-000 CAT 95C.
Issue: Flashing F on controller. No heat. Power button not functional.
Remedy: Made sure I had solid contact at all cord connections. Unplugged cord from socket at wall. Immediately reconnected.
Power is off, Power Button now functional. Turned it on and set the temp. Works great.
Thanks Howard975 for the boost toward the solution.
Posted on Jan 04, 2013
Return it, get a cheap unpretty heating pad,  get relief
Posted on Oct 09, 2008
  • wagz38 Dec 14, 2010
    Same deal....whats the deal??? Has Sunbeam just continued to put out garbage????
    Seems as so....so many of these complaints on line.
How to turn on heat with controller on my heating pad model cat92. It shows F-1
Hello, Martha -
I hope I am correct in thinking your heating pad is a Sunbeam.
If you have not yet checked the connection for the electric cord into the heating pad to make sure it is connected fully and properly, I suggest you do so.
Jan 11, 2018 | Heating & Cooling
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
Dec 07, 2015 | Sealy Heated Queen Size Mattress Pad - -
One control works and not the other control
I have a Sunbeam electric blanket. One control is blinking F2. How do turn that off?
Mar 05, 2014 | Sunbeam California King Arlington Heated...
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
Jan 25, 2012 | Heating & Cooling
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
Have heating pad model 818-7. blinking red light for high when connected- but no heat. what to do. I love this soft, terry cloth hour glass heating pad controller model number: SW204. e12107 is also on...
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
Dec 16, 2009 | Sunbeam 805810 HeatSense Heating Pad...
New heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Apr 26, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Sunbeam 805810 HeatSense Heating Pad Heater Logo
10,913 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
