Question about Husqvarna Designer I
My Husqvarna Designer I has an upper thread tension problem... the thread gets "caught" right at the beginning point of the threading process and the machine comes to a dead stop. There's major bobbin thread throw-up on the reverse side. Also, it refuses to consistently freemotion on my quilts. Many clunks, needle breaks, thread throw up, etc. Help!
  • 201 Answers
My guess is that it is the thread spooling off the reel that is the problem. Some of those specialty quilting cottons come on reels with plastic ends that have rough spots particularly knicks where you are supposed to "park" the thread end when you are done sewing. Run your fingers around the rim at each end of the reel and choose the smoother one to be the one closest to the threading mechanism. If neither end is suitable, flip the spool holder upwards so it is standing at a right angle to the machine, make sure the large spool holder is on then put the thread on - you won't need the smaller spool holder on top. Let the thread feed off from the right-hand side i.e. "under" the thread spool, across to the tension disks etc. Also be sure that the thread is not jumping out of that first thread tension slot.
Posted on May 26, 2010
Testimonial: "Thank you for your help! I have found that putting the spool in the upright position and bypassing the first part of the threading will help ease the tension problem."
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
Upper looper thread keeps breaking
try a new needles
check for burrs
make sure the thread is not caught anywhere
Feb 04, 2016 | Sewing Machines
Tension problems with top thread husqvarna emerald 203 sewing machine how do i fix
Make sure the upper thread is seated complete in the tension disk:
Remove the upper thread from the machine. RAISE the presser foot. Rethread from the beginning. Verify the thread path is correct The machine's default tension should work best at the midway point between high & low number.
Jul 29, 2010 | Husqvarna Designer I
Can not adjust the upper thread tension tight
If you are adjusting the upper tension on your machine and yet there is no difference to the sewing, it seems to me that maybe your upper thread is not in the tension disks correctly. Re-thread taking care to make sure the threads bed down into the tension disks. I pull off about 2 foot of thread from the spool and put my right-hand finger on the thread very close to the spool (the idea is to hold it down so it doesn't move) then use my left hand to take the thread through the thread run. Once I get close to the needle, I tug the thread a little and you can hear/feel it go into the tension disk.
Sometimes it looks like the top thread is the problem, but in fact it is the bobbin which is at fault. Re-insert your bobbin again taking care to click it into its tension slot. If you are still getting bad results, try loosening off the bobbin tension. Use a tiny screwdriver to turn the tension screw (the one just on the outside of the tension slot). Turn it no more than 1/5th of a circle at a time (to the right to tighten, to the left to loosen) then put bobbin back in and test. You should not need to adjust it more than two or at most three times. If you do, something is seriously wrong with your machine's tensions and it needs to see the Sewing Machine Doctor.
May 25, 2010 | Husqvarna Designer I
Good Day, On my Designer 1, I have a problem with the embroidery. The bottom thread comes up over the fabric and I don't know how to readjust the tension. Can you help me please ? Thank you very much....
Tension should be adjusted automatically by the machine when embroidery unit is engaged. However, if there is loose threads or fluff in the upper tension unit this could cause the tension discs not to properly close. Using a small brissel brush and remove any loose threads/fluff by brushing between the discs in the upper tension unit with the presser foot in the up position. Also try these tips:
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 14, 2010 | Husqvarna Designer I
The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Nov 04, 2009 | Husqvarna Designer I
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
I have a husqvarna Designer SE. After embroidering for a while the thread gets jammed in the bobbin area and makes a big clumped up mess. What's causing this? All I can do is squeeze my scissors under...
Most likely the thread is riding up and out of the tension disks. Look for the small, round opening in the pre-tensioner. It is the metal piece to the left of the horizontal spool pin. If the thread is on the horz spool pin, it will travel in the rounded opening. If the thread is fed in higher up, it can ride up higher in the pre-tensioner, causing it to not be pinched by the pretension spring and it may ride up and over the top of the tension disks. If this is a possibility, rotate the horizontal spool pin out toward you. Place a spool cap on it and feed the thread around it on the right side and below so the thread feeds into the pre-tensioner horizontally and I think that your problem will go away.
The only reason for this to happen is that you are loosing the upper tension for some reason so if my suggestion doesn't work continue to look at the upper tension assembly and the takeup lever.
May 16, 2009 | Husqvarna Designer I
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Oct 28, 2008 | Husqvarna Designer I
Designer One "broken thread"
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Feb 05, 2007 | Husqvarna Designer I
Sewing Machines Logo
175 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
