Will not turn on. like it has no power but it is pluged in
Will not turn on. it has no power but it is pluged in. was working fine turned off than 15 min later it would not turn back on. is about 10 years old.
  • 3,866 Answers
Ok without a model number I am going in blind and I hope you do not take that in effect to how you rate me today. Probably cause would be a fuse or a power supply issue. I cannot rule out any further without a model number or additional symptoms.
Thanks and please be considerate and leave a postive rating for your free answer today.
Posted on Apr 26, 2010
I have my GPS pluged in and the little red indacater light is on. but the unit will not turn on it has been stored for about 6 months. does it have to be pluged in for a few hours before i can use it...
hi buddyd56
press and hold the power button for up to 15 seconds...the 6000T 3000T and the 3050 all require you to hold the power button for up to 15 second if its in the off position or the battery is dead.. most all other magellan gps will start within 7 seconds if the battery is totally drain or its in the off position.
let me know if that doesnt wok, but it works if there
is no damage to the gps like a bad screen ect
good luck
bill
Nov 11, 2010 | Magellan RoadMate 6000T Bluetooth GPS...
Unit worked fine for 15 months then one day turned it on and nothing,light flashes and thats about it,prognosis?
Hi, If nothing happens when on, the first thing to look at and test is the cord. If nothing happens when pluged in , it is not getting eletric, Second thing to look at is the fuse. Good luck. Ron
Jan 19, 2010 | Coffee Makers & Espresso Machines
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
6 cyl 2.9. drove to work fine. turned off. 15
all i can say is check for power and ground at the fuel pump. get someone to turn the key to the on position (not crank!) and use a test light to see if you are getting power.
Aug 27, 2009 | 1987 Ford Ranger
My WD Elements 640GB Wont turn on.
I had the same problem. I fixed this by leaving the power supply connected with the wall socket for about 15 minutes, without connecting it to the external hdd. After that I connected the power supply with the external hdd and it worked perfectly. I hope this helps for you too!
Aug 02, 2009 | Western Digital Elements powered by WD 320...
Bradford white 15 yr old power vent runs constant
pilot light will stay on if it is a standing pilot. Turn water heater aqustat down and plug back in. you probably need to clean water heater or replace it. i have drained down a couple of them and took out gas valve and cleaned and put back in worked fine. If you get me a model # i can look it up and tell you some things to try. not sure on yours if it has a different temperature control or if the gas valve is a dual control .
Jan 30, 2009 | Water Heaters
Xbox 360 power brick turns rd when connected to console
When the light turns red that means the power brick is to hot.
Dec 26, 2008 | Microsoft Xbox 360 Console
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
